Alan your d**m straight on that. I have heard in some countrys you have to be registered and there's a ft lb limit on air guns. Get caught slipping a stronger spring in means jail time.
I hate to think it but there's more to worry about here in the USA than just the cloward-piven strategy anymore.
DCarr you just have to match the target to the gun sometimes it's dime size other times it's a barn
Grant they are single shot and shoot pellets only bb's will screw up the rifling and the barrels are slightly choked at the end of some of these guns.
On the Tell there's a pivot where the barrel meets then receiver you pull down on the barrel to cock and load it. The barrel has a link that pushes a guide sleeve back until it locks with the trigger sear. There's a spring inside the sleeve and a seal on the head of the guide.
The Diana works the same but it uses a lever under the barrel to cock it. On this diana there's a port on top much like a quarter turn gas valve that it loads thru.
