Oh boy, here we go again.
So I'm fooling around underneath the dent with the LMC catalogue blow up sheets. See, I was trying to do some learning and such. So I'm sheckin everything out and poking at this and prodding at that. Well, right about this time I get the cleaning bug and start to wiping off some grit and grime. Pah! I learned my lesson. Won't be doing that anymore. That there grime was what was plugging up the hole in the side tank. Yeah, I know, better now than later. So I spent the better part of the evening filling up gas cans and plastic jugs with fuel.
I guess tomorrow I'll be shopping for a new tank. I'm figuring if I can take the bad one off, the new one will go on the same way.
Being that I'm so wet behind the ears any advise or upgrades or things I may want to take into consideration while I'm replacing all these goodies.
I'm thinking new pumps, sending units, fuel lines and filters.
What am I missing?
Jake
What am I missing?
Jake
- 66fordtrucknut
The fuel gauge isn't working. What is the piece that needs to be replaced for that?36truck wrote:Wouldn't need a fuel pump as it is on the engine. Is the fuel gauge working now? if so you don't need to replace. Get the sock filter that goes on the end of the sending unit. Ford still carries it. Get new gas tank straps to hold it on unless there are in real good shape.
This sending unit sock filter is something I can order from the dealership parts desk?
Jacob
Yes, I have the two tanks. Both are 19 gallon. I did see where I could get a 35 gallon tank for the aft. Maybe a future upgrade.66fordtrucknut wrote:New fuel fill hoses, you'll be happy you did. So you have 2 tanks? My solenoid went bad on mine too.
Charlie
I don't know what a solenoid really is yet. Will you please explain?
Thanks Charlie
Jake
Grocery List
I'm going off this list:
I will order:
1. Tank
4. Sending Unit
7. Hose gas tank connection
8.+9. Clamps
I'm unclear if I need 2 and 3 or only one of them. (please advise)
Do I need 6?
Do I need 10? It says it is 77-79 and Im 75.
No tank straps are listed. Will the ones for the aft tank work?
Thanks guys.
I will order:
1. Tank
4. Sending Unit
8.+9. Clamps
Do I need 6?
Thanks guys.
Jacob, sorry I'm not much help on dents.But call or pm Tom at Flashback F100s (61-66 junkyard dog),
& tell him you are a member here. He is most helpfull & may have some good used parts to save you some money.
He is also very knowledgeable (sic ?) on Ford trucks and what you may need.
Your hose clamps should be fine unless you look at them & they are all rusted up.
Brian is most likely right on needing the instrument voltage regulator if the other gauges are acting up. The instrument voltage regulator is located behind the gauge cluster.
X2 on 61-66 junkyard dog knowing about these trucks.
Tom Williams
- 66fordtrucknut
Jacob the solenoid switches the tanks it''s on the frame rail, fwd of the midship tank. you'll se where the fuel lines come into it. Tom has everything I bought my stuff from him. That midship tank comes down alot easier than it goes back up, at least with no help that is.
Charlie
Charlie
62' SWB uni 223
66' F-100 Short/wide 352
78' F-350 dually dumpbed 400
12' F-150 5.0 3:73 LS
Good to know. From the looks of things dropping the midship tank yesterday after skool the straps could prolly be fabricated ifn I knew how to do that sorta thing.Fordman wrote:that larger aft tank will require larger strap sto hold it in if you try and upgrade it later. i am not sure the straps are available aftermarket or not. i didn't look in my dent book.
