A while back I had a question about the length of tubing that hangs under the heater hose fitting that threads into the intake of an FE. The one I had was corroded and I needed to fix it. Hawkrod let me know that the tube needed to be there to keep air out of the heater core, so I thought I'd bore out the fitting and braize a new tube in,,,,,,, But then I got to thinking,,,,,,,, Why not make a new one out of stainless steel and never have this problem again? And then I thought,,,,,,,,, Why not make the fiting that screws into the water pump out of stainless as well? AND THEN I THOUGHT,,,,,,, might as well make the intake nipple that connects to the water pump out of stainless at the same time!
I still need to add the wrench flats and the nipple to the intake fitting and I need to add the wrench flats to the water pump fitting but I was so excited about how they turned out that I had to put them up. The nipple that presses into the front of the intake went in sweet. I saved my set up sheets so I can make a couple extra sets, because if nothing else, that stainless is sure nice to look at.
