I started replacing the front cab mounts this weekend, and I found that I couldn't get enough clearance to get the new rubber bushings installed by lifting the cab with the floor jack. So I put the old bushings back with the new bolts temporarily. Do you have to do all four at one time? The back two are under the tank, and I didn't have time to remove all that this weekend.
Also, I found my howling 223 engine above 55 mph was due to a slipping fan belt. I've always heard a squeal with Ford V8's when they start slipping, but this was a slip on the generator pully. It's really no noiser at 70 mph than 55 mph now, except what you'd expect.
Cab mounts and fan belt
have to lift the cab from as far forward as possible with both front bolts loose to get enough tilt .lifting from the side under the door is not enough. also the rears should be changed same time as front so all are equal.
News to me too!
