Any one have access to a diagram showing the various wiring connections, misc fasteners, etc that need to be removed to pull the engine and trans? I tried All-Data, and have struck out. Tomorrow I will try hitting up the local library for a haynes or chilton manual, but won't hold my breath they have one.
Seems like it should be simple, but is nothing at all like our trucks. I expected the driveshaft to be able to slip forward, then drop out after removing the U-joint retainers, but I am not sure the trans has enough play in the slip yoke to let that happen, unless the engine has to be jacked up or pulled to get the room needed.
I am also pretty sure I don't have all the wiring disconnected, but so much of it is between the engine & firewall, I can't really see much to tell. I thought I might start to pull the engine, and see what really needs to be disconnected.
Thanks for any help.
Maybe I am overlooking something basic here?
