Okay, after busting 2 craftsman nut splitters, and countless hours with a hand grinder I thinik I finally have the 5.0 ready for extraction form the donor Tbird.
Questions.
1. my engine chain is a bit short. I currently have it running to head bolts at opposite sides/corners, left front, right rear. I had to fish it under the efi intake, and it looks like this way will dent the valve covers. I figure I can buy a differnt pair cheap/easy enough, but do I have to worry about damaging the intake?
2. AC lines. I have already evacuated the system. Will the standard ac/fuel tool work to disconnect these, or does the ford ac lines have a special, non universal tool for undoing the lines?
Pulling a fully dressed 5.0 EFI
- dotcentral
- dotcentral
- dotcentral
- dotcentral
Okay, intake question.
Again, this is a 91 5.0.
I think if I seperate the upper intake plenum from the lower, I will have more room and be less likely to damage something. Is it just four bolts holding the two halves together? I have all the electrical connections unplugged, and I have bled off the fuel pressure.
I only see four bolts, but don't want to break anything trying to force it.
I posted this on another message board, and was told that under the little "5.0" tag there are two more bolts. I always wondered why there was torque bit screws on those. Guess I get to try again tomorrow.
- dotcentral
I just pulled my N/A 2.3 /auto from my 93 stangdotcentral wrote:I finally got the engine & trans pulled. What a pain in the ass. I sure am glad I don't have to re-install this back into the T-bird.
man that was horrible.
Now I find that there are no similarities beyond visual between 2.3 N/A and 2.3 Turbo engines. I may as well be swapping in a piano
