I am getting more and more intrigued with the late Crown Vic front end swap on the Slick '60's truck, and I was discussing this idea with a guy I work with today. He is also a rodder and is working on a '50 Dodge - putting in an independant front end out of another Chrysler of some kind.
Anyhoo, he's also kind of a metal guy all-around and he brought up a subject I had forgotten about. Glavanic Corrosion happens between aluminum and steel when they are placed together.
I remember the problem that occurred with (I think) Vegas that had aluminum bumper brackets attached with steel bolts. The joint utlimately failed due to galvanic corrosion.
Soooooo.......could this be a problem with the aluminum Crown Vic crossmember? Has the problem been solved through alloys added to aluminum?
Galvanic Corrosion and the Aluminum Crown Vic Crossmember
- Gary Seymour
Not an issue if the frame is well painted, the 2 metals never actually contact.
Gary Seymour
I have a lot of experince with aluminum corrosion from working in the aircraft industry most of my working life and my solution for the situation you are talking about would be to powder coat the aluminum parts before assembly that should solve the galvanic corrosion problem. Make sure to paint the frame where the aluminum makes contact with it.
I'm not sure where it is available but there is available mylar film that is adheasive backed that I would also use as a barrier between the frame and the aluminum parts attached to it.
I used this proceedure when I replaced the aluminum clad doors on a moving van trailer and after 3 years there in not a hint of corrosion. The hinges are steel so every thing was painted before it was put together and we also used clear silicon between the parts to seal out water and air.
- Gary Seymour
biggest issue in this area for most to worry about is the alternator bolt. also affects aluminum intakes. anti-seize takes care of that. same reason the aluminium distributors like to get stuck in the steel intake.
