gear and rpm chart?
Mike P
gear and rpm chart?
Post by Mike P »
does anyone have a chart that will give me a clue on rmp @ diffrent speeds for a 65 f250?
mike
64 F 100 223cid
65 F 100 300cid
65 F 250 390cid
dotcentral
Post by dotcentral »
Several out there. you have to know a few things to make it work. Rear end ratio, tire size, final drive ratio (usually 1.0, or less if you have overdrive).
http://wahiduddin.net/calc/calc_speed_rpm.htm
