heavy duty extension cord
- ezernut9mm
hey guys, i need a extra heavy duty extension cord to run a 110v welder. i know this is not optimal, but my good wiring is at the back of the house and i will need to get the juice to the drive way to weld up my cab mounts.
i will need about 50 ft of cord. will 10/3 be enough? home depot sells a 50ft 10/3 contractor grade "rigid" cord for about 55$.
if this is not enough, could someone point me in the right direction as to gauge and where to buy?
thanks, chris
thanks, chris
- Alan Mclennan
- 65 66 Ford
First, how many amps is the welder going to draw? If it is a small welder it should be between 12 to 18 amp rating.
Second, how many amps is the circuit in your back yard rated at? You can check the circuit breaker that feeds it. Does this circuit feed any other items that are on when you would be welding?
Fran
65 Ford F100 CC style side looooongbedddddd
Be American buy American
I use a 15A/125V 50ft. cord for my mig welder but am also using a dedicated circuit just for that unit. Even on a higher setting - frame type welding, I have not had any problems.
If you're doing a lot of sheet metal welding, then you should be fine, but I agree to run the line and see what else is on that circuit.
i have a 10-3 power cord rated for 30 amps wired in to its own breaker. its not an extension cord but flexible outdoor wire (heavy insulation, stranded not solid wire)with an outdoor receptacle on the end. its about 75 feet long and runs my compressor and/or welder just fine.
you can see part of it on the ground in the left side of this pic
my welder has maybe a 6 foot cord so unless its inside and stationary its kind of useless.
same with the compressor although a long air hose helps.
sure is nice to be able to wheel the compressor 75 feet from the barn and another 50 feet of hose and work where i want.
- Roger Carter
Ezer,
Most 110 volt welders work fine on a 20 amp circuit. Typically, #10 wire is rated for 30 amps. Using a 50" long #10 cord, as you described, should work OK. I doubt you will notice any difference in the performance of the welder.
The Home Depot cord should work great.
As other posts have said, an extension cord is not ideal, but for your desrcibed usage ii will work.
For what it is worth, I am a licensed electrician, with over 40 years experience.
Roger Carter
Roger Carter
- ezernut9mm
thanks for all the replies gents. i don't know how many amps the welder will draw, but it is a smaller unit. i want to say it's a miller, but i can't remember.
the back porch is all new wiring on a 20 amp circuit. there is nothing out there but receptacles so nothing else will be running at the same time.
i know that this is not the best way to do things, but ya do with what ya got.
I have been running mine with a good outdoor 3 wire 50' extension cord, for the low amps and short bursts involved with sheetmetal welding I have no issues what so ever. The welder itself is plugged into a 20 Amp power strip on my cart that is plugged into the 50' cord. The cord never even gets warm (other than the heat from laying in the sun). This is a nice setup as I can move the whole cart around with all the body tools, grinder, sander, 3" cutoff tool, & welder as needed. This way I have everything right where I am working.
If I have to kick the amps up (frame welding etc.) I just get into the garage where I don't need the long cord.
- ezernut9mm
garage, what's that? lol we're still on for that old welder, i just have to find time to come up and get it.
And that would be it on the cart in that pic too.
