1962 Unibody Kick off
- Gary Seymour
Got some stuff done, ready to mock up the front end and brakes. Also received the wheels practically OVERNIGHT from Coker! Wow, Ordered them Monday night and got them this afternoon. Best part they came powder coated black. Kinda like that look, I just may leave them the way they are.
What do you guys think? I am going all black with the truck eventually.
[img][img]http://i1230.photobucket.com/albums/ee4 ... C01922.jpg[/img][/img]
[img][img]http://i1230.photobucket.com/albums/ee4 ... C01928.jpg[/img][/img]
[img][img]http://i1230.photobucket.com/albums/ee4 ... C01927.jpg[/img][/img]
Family First!
fire truck
64shortbed
Find a regular Slick door at a junkyard - makes a great patch panel for that bedside - curve is the same.
Those wheels & tires look really good!
- Hookedtrout
Greg,
Thanks for the tip. Maybe where I'm going in the AM I can pick one up. What do ya think Pete?
Cory,
I have 15x6 on the front with 225/70 and 15x8 on the rear with 235/60. I was worried the fronts would be taller but it turned out the rear tires were a bit taller. Exactly what I wanted.
Cory,
Family First!
- Hookedtrout
Thanks!noley99 wrote: Cory,
Cory
1962 F100 SWB Unibody, 223
1931 Ford 5 window coupe
Okay, back at it today as the weather is perfect (except for the smoke).
Installed my new brake booster and master cylinder. Cudos to the manufacturer for the ease of installation. It needs to be because there were very little instruction
Got that "kick start, wood burning heater" out also. Found that this truck was an original heater delete truck. Wish the previous owner had left it that way.
Master Cylinder and Booster Mocked up. So very easy to install!
Knockouts still in place and bolt holes plugged.
Family First!
Not sure if it's just in the South or what but after dissecting this old heater system it's apparent that it was an option. I've got three holes to patch in my fire wall where the previous owner which by the way was really the only owner drilled holes.F7BIGJOB wrote:
Just from what I've seen in New England, I thought heater delete was only up to 1952 on FordsThat may not be the case now, is that an option for hot climate areas and how late of an option was/is that? Curious.
Family First!
Got the disc brakes mocked up yesterday. Took some modification of the calipers but relatively easy to install. Plan is to get it in the garage Monday and remove the front clip and engine. Think I may have the 223 sold
Also found a 302 and a C4 out of a 82 Ford Truck that runs well for $400 from a buddy he is going to throw in the tilt column and cross members. Question about those. Will these work or can they be modified to work?
Tool
Modification
More Mods
Bracket Installed
Finished
Tool
Modification
More Mods
Bracket Installed
Finished
Family First!
What's left of that ridge on the caliper going to clear the bracket after the brakes wear down?
I didn't bother to check that when I did mine - I just took the whole thing off.
[albumimg]2226[/albumimg]
Good tip Greg, I will take the rest off when I break it down. As you can see I have some blasting to do!Greg D wrote:What's left of that ridge on the caliper going to clear the bracket after the brakes wear down?
Family First!
Well, I got the truck inside today after some reorganization of the garage. Had a few hours left so I started removing the front clip. Got the radiator support out as well as the lower valance and bumper. I should be able to get the fenders off today after some baseball practice with my son.
Check out the rust!!
Family First!
Got the front end off and the engine out over the last few days thanks to my #1 helper.
Just got off the phone with my Dad and he has secured me a 1992 302 with EFI, all wiring, ECM and a 5 speed tranny for free!!!!
That made my day as every avenue I've been down lately has closed at the end.
Here are some pics of the last few days.
Family First!
