Garbz Maniacial in the closet Building of a 63 Ford truck
Garbz
Post by Garbz »
Shawn
I cant answer the Hedders thing. You can basically place the engine anywhere you want for clearance. Block huggers for a fox should work as it is all empty space.
You can use your stock 65 66 column. and just make up the parts to fit to the rack. My column is a little lower than a stock 65 66 in the picture posted and the frame is 2 inches higher.
For a welder i used the MIGs a Miller 220V or the Esab 220V at the shop. For the little things i used the TIG.
The ball joints and things are all readily available at any parts house. Basically the same upper and lower from 57 to 97. Doge used the same components on just about everything.
For a brake booster use a mid 90s ranger bolted to a later yarded bracket. Steve uses these on all his truck and rod builds.
I will be doing Disc brakes on the rear so no stock prop valve will be needed other than a wilwood in line.
Garbz
Shawn F.
Post by Shawn F. »
Thanks for the info Garbz! If you have any other tips then please feel free to post them because they will help me greatly!
Garbz
Post by Garbz »
Heres some new shots.
Need to do a litle machine work to fit the stock steel wheels on the Hubs or just pick up some dodge steelies.
Made up a couple sets for Steve today. Cut to fit mounts for FE's
More to come tomorrow.
Garbz
Shawn F.
Post by Shawn F. »
So if I want to run the Dodge fullsize truck 5X5.5 hubs I will need to machine the hubs down to fit my stock wheels on my 66? How much bigger is the center hub where the bearing is at compared to a stock 76 F100 hub? Reason I ask is because I plan to go with American Racing wheels and if the hub is not smaller than what the stock 76 F100 disc brake hubs are then they will not work. I just dont want to do this front end and have the smaller bolt pattern and have to redrill my rear axles, drums, etc...
Shawn F.
Post by Shawn F. »
Also, Garbz would you happen to have a set of the dakota directions on the internet you can possibly Email me? Reason I ask is because I am going to sell my beams and everything off the front of my truck such as the beams, hubs, P/S, etc and just want to know what I have to measure before taking any stock parts off the front end. I'm ready to do this front end in the next few weeks and get it going! :D
jkimbrel65
Post by jkimbrel65 »
Ford disc rotor across the snout where the rim rides is 3 1/2 and dodge is 3.Stock wheel should fit just fine
I tried being normal once...
Garbz
Post by Garbz »
Here is a shot with the tire mounted. I need to either machine the hub a tad or clearance the rim.
Here is the engine mounts in place.
I need to do some floor surgery with Z notching the front frame.
jwh f-100
Post by jwh f-100 »
Very impressive work Garbz!! Wow that thing looks like it will be nice n low even with the suspension hanging... Is your MC & Booster gonna clear OK???
Jason
Beer will change the world.
I don't know how but it will.
DCarr
Post by DCarr »
Can you say "almost a roller" ? Nice, what happened to the cammer?
Garbz
Post by Garbz »
It is sitting in my garage. Along with the five speed.
I had this nice running 390 sitting around, and a nice set of 410 merc valve covers.
It should be a roller by the end of day tomorrow.
Garbz
Garbz
Post by Garbz »
Here is a few more shots of the build.
Made some 9" long adjustable upper bars.
Upper bar brackets for the axle.
Upper and lower bars at projected ride height.
Attachment to the axle.
Upper top bar attachment. Neat little thing.. Used 3/8" puck and the outer shell to support the 1/2" through bolt.
Stock ford wheels are a tad to close for the hubs i purchased. 1987 D150 full size dodge. Need to take just a smidge off the hubs.
Shot from the front with wells set on but not tightened.
All i need to do this weekend is place some axles in the rear and trim the front hubs a tad.
Garbz
[/img]
Shawn F.
Post by Shawn F. »
Looking great Garbz!
Garbz
Post by Garbz »
jwh f-100 wrote:Very impressive work Garbz!! Wow that thing looks like it will be nice n low even with the suspension hanging... Is your MC & Booster gonna clear OK???
Ride height is anticipated to be six inches at the rockers at a level body.
With using the FE i will mount the Booster/MC outboard in the clutch location and use a C6 with a Gennie floor shifter. Just need to do a modification on the housing and make a new brake shaft.
Its the old saying"shit happens" I knew it wold be close with the Z notch.
Garbz
Garbz
Post by Garbz »
Shawn F. wrote:Also, Garbz would you happen to have a set of the dakota directions on the internet you can possibly Email me? Reason I ask is because I am going to sell my beams and everything off the front of my truck such as the beams, hubs, P/S, etc and just want to know what I have to measure before taking any stock parts off the front end. I'm ready to do this front end in the next few weeks and get it going! :D
Shawn All you need to do is clearly indicate the front axle center line on the top of your rails. Everything else goes including the cross member. The Dakota comes with the boxing plates fully welded to the cross member. It is fully welded in a JIG and there are notches in the plates to indicate the axle center line. All you do is level your frame and level the crossmember in place. it is nearly impossible to screw it. Steve sends instructions with the unit but its pretty simple. A little trimming of the rail edges with a grinder and it slips in place. square it up in the chassis and Tack weld it in. the rest is pretty much trim out the old rail for the hats and slip them in place. Then full weld it in.
Garbz
jkimbrel65
Nice work Dave.Mine showed up today :D
Shawn F.
Post by Shawn F. »
Thanks for the info Garbz! I can't wait to order my front end! :D
DCarr
Post by DCarr »
4 link looks good,Garbz. 390 makes more power anyway-but I'd rather shift than be shifted :lol:
But as you know sometimes you have to do what's convenient.
The upper links look like 1-1/2 .120? that's what I used on a waterpumper buggy I built
with a 3-link- 2 lower parallel arms and a wishbone on top for axle location.
I used polys on the front pivots & 3/4 heims on the axle end. Put the wishbone on
the top to keep the roll center high-I wanted it to slide instead of dig in on the sand.
Going to put a similar setup on my 64 except with heims F&R and 2 separate
angled upper links instead of the wishbone.
Anthony
Post by Anthony »
NICE :thumright: ...I'm enjoying this follow along ride Garbz, keep up the great work....Anthony
Roger Carter
Post by Roger Carter »
Garbz,
You make it look and sound so easy! If only it were. The workmanship looks outstanding. Really enjoy the pictures and detailed descriptions.
Thanks,
Roger Carter
ras4434
Post by ras4434 »
I was thinking more about saying something negative about the build but for the life of me I cant come up with anything...................dang when sour grapes dont work.........I AM ENVIOUS of the work and skill... :D ..............Ross
