1964 f-100 front suspention Help please!!!!
BTW, with the right Toyota 4x4 Steering box PS is doable. Mine actually drives just fine even with the 225 x 60s on it and the 14" steering wheel. Having the front end in good condition, well greased and properly inflated tires can make a world of difference on one. It's also alot easier to plan ahead just enough to always be moving at least a little while you are turning. This comes a bit more natural to me though, my first car had standard steering and about 40% of them since too. My rotator cuffs are shot and I can manage mine just fine.
Farmboy
Post by Farmboy »
Greg D wrote:BTW, with the right Toyota 4x4 Steering box PS is doable. Mine actually drives just fine even with the 225 x 60s on it and the 14" steering wheel. Having the front end in good condition, well greased and properly inflated tires can make a world of difference on one. It's also alot easier to plan ahead just enough to always be moving at least a little while you are turning. This comes a bit more natural to me though, my first car had standard steering and about 40% of them since too. My rotator cuffs are shot and I can manage mine just fine.
Do you know which steering box it is.All I can find just goes to 1960. I'd like to get one and some king of an aftermarket column to give me a little more room behind the wheel. I've seen a couple of power disc brake conversions on the net and I'm gonna do that upgrade too! Just wating of a few parts books to get here in the mail and then I'm gonna down her and get started! But dealing with the suspense is killing me. I wish I was smokin the back tires now instead of looking at it setting in the garage with no parts to work on it with.
61ford
Post by 61ford »
the toyota box is an early 80s box. i bought a door off someone over in maryville few months ago he joined here and all he ever posted was in the classified section.he said he had one he just had to find it he also had alot of rust free stuff.ill see if i can find his email.hes over in maryville just off hte motor mile
Ryan
351w/Aod
61ford
Post by 61ford »
Ryan
351w/Aod
Garbz
Post by Garbz »
Here is a shot of a 88 truck tilt column installed in my 64 "Christine"
[albumimg]294[/albumimg]
It is pretty simple, It hangs on a 427 rod bracket and I double D ground the steering box stub and attached the column to the box with the stock 88 ford through bolt.
The tilt works nice.
Garbz
[/img]
jwh f-100
Post by jwh f-100 »
I just price a 8' bed floor. I used a vin off ebay for a '06 f250. The price is $543.00...... :cry: :cry: :cry:
I guess it is back to looking for a donor floor... :cry:
Jason
Beer will change the world.
I don't know how but it will.
Johnny Canuck
Post by Johnny Canuck »
considering you could pay triple that for a tonneau, easy, that ain't that bad Jason
Farmboy
Post by Farmboy »
Garbz wrote:Here is a shot of a 88 truck tilt column installed in my 64 "Christine"
Garbz
[/img]
Thats a nice looking rig you got there.
Farmboy
Post by Farmboy »
61ford wrote:the toyota box is an early 80s box. i bought a door off someone over in maryville few months ago he joined here and all he ever posted was in the classified section.he said he had one he just had to find it he also had alot of rust free stuff.ill see if i can find his email.hes over in maryville just off hte motor mile
If I new for sure what it was I could probably find one at the pull-a-part junkyard. If you've never been there you should check it out. Nicest junkyard I've ever been in.
You want the toy power steering box from a live axle 4x4 pickup or 4 runner (84 & older?) it's easy to spot the right one - it's location on the frame is in front of the axle. If you are seeing this listed as a swap for a 1960 works basically the same on a 61-64.
Garbz
Post by Garbz »
Jason
Look to a 73 to 79 for a new bed floor. You can cut off the quarters and place the bed sides of a 61 to 66 on them and they fit really well. Much easier than placing a floor and all those spot welds.
I did this for the Suicide Crew i built using a 79 tub and 63 quarter panels from a Uni.
Garbz
Garbz
Post by Garbz »
Farmboy
the entire set up out of my truck will be available in about a month. As i dismantle "Christine"
Garbz
jwh f-100
Post by jwh f-100 »
Garbz wrote:Jason
Garbz
Hmmmmm But then I'd need to shorten it....
found another floor at LMC http://www.lmctruck.com/Features/FC/FCSTY.htm
Jason
Garbz
Post by Garbz »
No font or "pattern" matches the 64 to 66 floors.
No patch panels available, match the width and depth of the pattern of the 64 to 66 floor.
Garbz
kenk96
Post by kenk96 »
Thanks Gabz...
JWH, where did you price the replacement bed panel for the '06 F250?
jwh f-100
Post by jwh f-100 »
kenk96 wrote:Thanks Gabz...
just a local ford dealer...
Jason
