lincoln 460
jakdad
Post by jakdad »
Take the advice about changing out cam and timing chain. Wouldn't hurt to change pistons also.
Jim
clevor347
Post by clevor347 »
Not trying to say anything outta place but I gotta spare set of 68 460 heads outta a lincoln continental, which are 4v & the matching intake to go with it if anyone's interested. It'd open up that 77 alot. :lol:
1966 ford f100 - project on hold for now
1970 ford f100 - dd
1977 international harvester scout 2 - MUD :D
Garbz
Post by Garbz »
Ezer, what LMC and others refer to is the MEL series of lincoln engines the 430 ect...The aftermarket mounts will not fit these engines.
I Have a 472 CI EFI vesion of the 385 in "Christine" and it will be transferred over to the crew cab. Great engine and pretty stout.
Garbz
Jonas
Post by Jonas »
ezernut9mm wrote:i agree, i seem to remember some negitive thoughts on lincoln 460's for some reason and i can't remember why.
it supposedly has less than 80k on it.
pics:
The negative thoughts might be from alot older Lincoln 460. It's a diffrent engine. MEL
The engine in the picture is a Ford 460. I would at the least change the timing set. I would have suggested headers, but FordBoyPete knows his shit.
I have used the L&L Mounts. I could not find 460 mounts from a 73 to 78 truck. 400 bucks for a good motor and transmission seems like a deal to me. Good advice about moving the oil drain plug.
1997 F250HD 460 4X4
2004 RoadKing
1984 FLHS
1978FXE
Phil
Post by Phil »
I paid 300 for my 74 MkVII 460. The longer C6 was a pain and I ended up tossing it and getting a Torino C6 (13.5" tailshaft VS the 17" Lincoln with funky mount)
$400 seems too high to me. Mine was complete as well.
BYR has touched on every point you need to know about that engine and is dead on with his insights on rebuilding and buying
Slick Fan
Post by Slick Fan »
That's the first time I've seen a Chevy orange 460. :lol:
These guy have covered pretty much all the bases, so I won't add anything.
That intake looks aluminum from here...that might be a good sign of things to come. :D
ezernut9mm
Sweden
Post by ezernut9mm »
Garbz wrote:Ezer, what LMC and others refer to is the MEL series of lincoln engines the 430 ect...The aftermarket mounts will not fit these engines.
Garbz
ok, i know about mel's. dont we all want crank driven power steering and hydraulic wipers?
it makes me feel a little bit better about this being the same as a ford 460 then.
too bad i sold a set of d0ve heads last winter because i thought i'd never use them.
ezernut9mm
Sweden
fbp, thanks for your input as well..
Garbz
Post by Garbz »
I see a toy pack up and picture delete in here somewhere....
Garbz :roll:
Slick Fan
Post by Slick Fan »
YIKES! :shock:
BackyardRest
Post by BackyardRest »
Are you aware that retarding the cam will change the power band UP?
Have you ever degreed a stock 460 '77 cam to see if indeed it was retarded 3 degrees?
Jonas
Post by Jonas »
It is suprising that headers alone would give you a 20% HP increase.
Also intersting that a stock 429 from the early 70's was rated at something like 340HP. Is that rating flywheel or rear wheel?
Is the diffrence heads and compression?
1997 F250HD 460 4X4
2004 RoadKing
1984 FLHS
1978FXE
BackyardRest
Jonas wrote:It is suprising that headers alone would give you a 20% HP increase.
Flywheel, ALL 460's after 71 were dogs in stock form. (except the 74 PI)
and other year PI's which actually ran very well.
I have a 69 460 rated at 360hp and 500lb ft. After 1971 the ratings were net (which I remember to be back of transmission with power accessories) The 72 & Up were usually around 200hp rated. Remember the 74 Cop Car to be 275hp. Still have that engine floating around here somewhere... lol
A rear wheel hp using a C-6 trans would be approx 125hp less than flywheel. Using a 4spd around 100hp less.
Todays transmissions and powertrains take up a lot less HP.
Spent many a hour on both engine dyno and chassis dyno just to see what the old fords would do. That was my experience.
(would be other losses too as the engine dyno figures would be normally open header an closed exhaust on chassis dyno.) From what I found going open header to a good system with mufflers usually around 15hp. Again depending on HP level....
Found the 429/460 engines seemed to like larger header sizes than a comparable FE would.
BackyardRest
Just put a cork in it
Garbz
Post by Garbz »
Wow the next Hawkrod, No offense Hawk:wink: ...Please go over to the 460.com forum and argue there... Here we just want to be pleasant and create no friction.
Garbz
BackyardRest
Garbz wrote:Wow the next Hawkrod, No offense Hawk:wink: ...Please go over to the 460.com forum and argue there... Here we just want to be pleasant and create no friction.
Garbz
Its not me who said '77 460 pistons will not support headers... LOL
What did he try to do bolt the headers to the pistons?
Put a Cork in it Garbz, then the backpressure will help your shcitz
Fanatic
Post by Fanatic »
BigTim
Post by BigTim »
One thing on backpressure. I put a catback Gibson on my 5.4 F150 and it lost seat of the pants acceleration. Once I added the programmer and Airaid CAI I regained what I lost plus a good bit more. I have no numbers to back any of it up other than the ass dyno, and I can run of and hide from stock 5.4s now, but with just the exhaust, gutless.
ezernut9mm
Sweden
well, that was interesting.
65TremecGT
Post by 65TremecGT »
I say if it looks good try it out, driving a beater 74 with a stock as can be 460/c6 while doing some rock work at my house and its a pleasure to drive, had a yard of river rock in it and pulled great, stopped not so great! its a ex cab longbed f150 trailer special.
