Okay, I set the timing at 10* the other day and filled it with 87 octane. I'm going to run a tank with that and see what the mileage is. Then I'll do another tank with 89 octane and see what happens.BarnieTrk wrote:
As I recall, your '65 352 would have about a 9:1 compression ratio new/fresh.
I bet you'd get better mileage if you bumped up the timing to 10* and used 89 octane (mid-grade) fuel.
BigMike,
I challenge you to try these two changes for a similar two weeks as your first mileage test. Let us know how it does....
BarnieTrk
Truck sure has more pep and isn't pinging.
