MPG's
BigMike
MPG's
Post by BigMike »
I filled the tank two weeks ago and again yesterday. I got 9.8 mpg on the last tank.
1991 Porsche 964 Cabriolet
2006 Cheby Silverado
Re: MPG's
Post by Gritsngumbo »
charliemccraney
Re: MPG's
Post by charliemccraney »
If that's around town, it's not that bad. A lot of idle time. They're not economy cars.
I've never checked my around town economy but I typically fill up once a week and it's usually about 12 gallons and I tend to go at least about 140miles a week. I try to drive economically so the way I typically drive, it may look like I only have a stock 223.
Uncle Skip
Re: MPG's
Post by Uncle Skip »
MPG's? What are MPG's? We don't need no stinkin' MPG's. We have 3 carburetors. 8)
foodstick
Re: MPG's
Post by foodstick »
well I think the tired 300 makes around 12 in the Ltd Uni.... I know i used to hope for more.. But not knowing the background on the motors previous life ? i guess its what it is.
kid and I got it from his buddy for 50 bucks, and it had been laying in a barn for several years.. No idea on the history other than supposedly it came from UPS ? maybe out of a work truck or something.. I pretty much cleaned it up, changed the oil...and bolted it in ! people with a better ear than mine have said they think they hear some pin slap in one cylinder...
BarnieTrk
Re: MPG's
Post by BarnieTrk »
BigMike wrote:I filled the tank two weeks ago and again yesterday. I got 9.8 mpg on the last tank.
What is your engine timing set at?
What brand of gasoline are you running in it?
What is the gasoline's octane rating?
What % of your driving is over 60 mph?
What % of your driving is under 50 mph?
For your 352-V8-powered, NP435 4-speeded, DANA 4.10 geared, 4,000+ lb (empty) F250 to get an average 10 mpg, I'd say you're doing PRETTY WELL! :clap:
BarnieTrk :steering:
jkimbrel65
Re: MPG's
Post by jkimbrel65 »
Uncle Skip wrote:MPG's? What are MPG's? We don't need no stinkin' MPG's. We have 3 carburetors. 8)
X2
Mike
I tried being normal once...
Re: MPG's
the 2 times i checked the MPG on my 61 was going to SlickStock 3 & 4
stock 4x4 truck with 223 and 4spd @ 55 mph ....... 13.5 MPG
and i have only 1 carberator... and it only has 1 barrell !!!! :twisted:
oldtrucks
Re: MPG's
Post by oldtrucks »
My 62 gets 13.5 also, its a bone stock 292 Y block with a granny 4 speed and I don't have a clue what the rear end ratio is. I have a 2.73:1 rear I am considering putting in it don't know if it would make much difference but it's worth a try I guess. I'm like Skip no more than it gets driven mileage isn't an issue. If it were a daily driver it would be some what of an issue.
Mike Kincheloe
Mikes Old Trucks
I restore old trucks and cars
1950 F7 Cab and Chassis
1976 F150 4 Speed 4 X 4
1996 Taurus
oldtrucks
Re: MPG's
Post by oldtrucks »
Mike Kincheloe
Mikes Old Trucks
1996 Taurus
Re: MPG's
The only time I've seen better than 12 mpg, OR 55 mph with my Uni, was downhill from Kansas. And that was on a trailer behind a 3/4 ton Chebbie :peepwall: The good part is I've had to only fill the tank once in well over a year!
62galxe
Re: MPG's
Post by 62galxe »
My 292 got a little over 13 on my slickstock trip at 75. :twisted:
1963 uni PATINA BLUE
1965 short bed
aarons428
Germany
Re: MPG's
Post by aarons428 »
WOW you get 13 mpg my truck gets about 4GPM hahahahahaha yes i said GPM I love it!!!!!!!
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
c-6 wide ratio modified
torino front stub
oldtrucks
Re: MPG's
Post by oldtrucks »
opps sorry for the double post must have fat fingered something.
Mike Kincheloe
Mikes Old Trucks
1996 Taurus
BigMike
Re: MPG's
Post by BigMike »
What is your engine timing set at? 6*
What brand of gasoline are you running in it? BP mostly
What is the gasoline's octane rating? 87
What % of your driving is over 60 mph? 10%
What % of your driving is under 50 mph? 90%
See bolded answers above
Re: MPG's
my towtruck gets rated at gallons per hour
bored out 390, 4 speed, d70 posi rear d44HD front 4:10
today ran (plowed) 3.5 hours, and drove 4 miles on highway with 4 tire chains @12mph, 3 gallons used.
HiBoy63
Ireland
Re: MPG's
Post by HiBoy63 »
The old knock on the Ford Fe was you get 10 mpg loaded or empty. We used to laugh about that when gas was just $1.00 a gallon. 352,360 and 390. This was a known fact they werent built for mpg just work. Lots of low end torgue med HP and bad mpg. I dont remember Mike did you have a 2 barrel carb. You might do better going to a 4 barrel and try to stay out of the back 2 barrels. That might help a little.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
Heritage country Flag
foodstick
Re: MPG's
Post by foodstick »
Someone broke 20 mpg with a 352 on one leg of the trip to SS 1 !!!!!
DV65CustomCab
Re: MPG's
Post by DV65CustomCab »
I get 15 mpg pretty consistently with my 352. What's killing the mileage in the O.P.'s truck is the 4:10 rear. You're never going to get anything higher with that ratio.
Stop The Longbed Hate! :)
Now: '93 F150 Lightning
BigMike
Re: MPG's
Post by BigMike »
DV65CustomCab wrote:I get 15 mpg pretty consistently with my 352. What's killing the mileage in the O.P.'s truck is the 4:10 rear. You're never going to get anything higher with that ratio.
Yep, that was discussed at length in another post.
I'd like better mileage but it isn't a DD. I'd probably drive it more if it got 14-15 though. It's depressing when you think of it as $0.36 a mile.
