63 unibody
dragginwagon
Post by dragginwagon »
thanx.... naw raw steel from sanderson
kstones63
Post by kstones63 »
I am running into the same tight tolerance for my 4.6 DOHC. I am going to use the Sanderson Headers on mine too. By their dimensions on the website they should fit just like yours. Tight but it should go. I hope the steering shaft clearance is okay.
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
mikewirth
Post by mikewirth »
what frontend are you using? I have great clearance with boss exhaust manifolds on my 4.6 but I am using a crown vic suspension
dragginwagon
im using a camaro, but im sure ur askin him... i have no idea what he's using.
im pretty happy with these sanderson headers, for the money they seem very nice.
got some more work done today, motor mounts built and mocked up. tranny cross member built ( still needs tabs welded on)
fire truck
Post by fire truck »
Lookin good dude, are you going to try to get this thing to scrapin the coast this year?
dragginwagon
i doubt it... with the baby and all money will start to dry up. maybe take it to RA show in memphis late this year
fire truck
Well if you come down, truck or not, hit me up....
Max
Post by Max »
Just curious what tools you're using to cut this metal with. Good stuff!
dragginwagon
thanx.
i have a JET brand band saw for the tubing and a plasma cutter for the plate stuff.
dragginwagon
got a bit more done...
buddy of mine told me about a shorter oil filter...tons of clearance now
the motor and tranny are completely mounted now
MadMaxetc
Post by MadMaxetc »
Looking good.
You have the same welder I do! I love mine, very easy to use.
My Build Thread
dragginwagon
thanx, yeah i like it....im ready for a tig though!
i dont think i ever posted a pic of my rendering for this truck..... plans have changed since i first started:)
Reds Rod Shop
Post by Reds Rod Shop »
Wow.... Not sure how I've missed your thread but man it looks great. Congrats on the addition to your family. Keeo the pics coming. I need the inspiration.
dragginwagon
preciate it! things might move slow for the next week or so.... gave my dad the axles and all four rotors to do some machining on em ( bolt pattern change and changing the hub/ bore diameters )
i need to burn everything in and get it ready to blow back apart to take it off the table. i dread doin all the mounts for the body on the frame.... think the body is gunna go on a rotiessrie 1st and fix the mounts on it, then i'll deal with the frame side of it.
dragginwagon
did a lil after work
made the dipstick tube fit.... took a couple bends and i still have to make the tab work
my dad finished up the front rotors for me. axles are next
dragginwagon
been messing with other peoples stuff but i got a lil done on this last few days
mocked up my gm alt, 82 e350 power steering pump, and mini starter.
hoses will be fun
driver hub/ brake assembled
2000 jeep rotors and redrilled axles
axle bracket and 3/4 ton gm calipers
dragginwagon
i replaced the axle bearings and seals today. also welded the pass side caliper mount and got it all mocked up. been welding the frame and four link mounts when i get a free chance, tryin not to cook my welder also!
dragginwagon
got some shop time today.... tacked inthe front cab mounts, its a shortened stock one
built one of the rear cab mounts also... still need to build one more
MadMaxetc
Post by MadMaxetc »
Don't quite understand the rear mount. Fab work looks nice. :)
I am sure it will make sence when you get it on the frame.
Looking good!
My Build Thread
dragginwagon
thanx.
its missing the hole on the top for the bushing/ bolt to go through, maybe thats messing you up? also the hole/ tube through the side is just for looks and strength.
basically it'll weld to the frame just like in the scrap piece in the pic and the bushing will go on top then the cab will sit on it. it'll use the spot where the gas tank mounting bolts go.
