Slickmainers (Gregg) 65 project
slickmainer
Post by slickmainer »
got one of my doors painted, but how do you get tape adhesive off a door that isn't clear coated yet? I had to tape off some areas for a two-tone look. the tape residue stuck to the blue. Im afraid if I rub wax/grease remover on it, the blue will come off? yes?no? soap and water?
anyway, its a custom cab, but I dont have the trim, nor the panels. There are lots of extra holes, but till i get some money to buy all that, I used a little or Icemans (Brian) door scheme, and some of oldtrucks (Mikes) scheme.
If I do buy the trim and the panel, i'll just put them over the stripes and leave the bottom. The access panels will be blue as well.
note: Kids foam letter stickers work great at rounding out a line. Took some letter O and cut them in half, stuck them on at the end of a strait tape edge and boom, easy rounded lines
--Gregg--
you can't get there from here
Rusty 63
Post by Rusty 63 »
I'd consider filling those extra holes with pan head machine screws painted blue so they kinda blend in & look like they're part of the "structure" of the door. Your average Joe at a car show wouldn't know the difference, just us & we won't give you a hard time about it....
Sorry - I've got no clue on the tape issue. Only time I've ever two-toned anything, I waited days, if not weeks, after I painted the first color because I was paranoid about that possibility.
tray
Post by tray »
Doors look good try some simple green on the adhesive.
slickmainer
oddest thing on the white part of my doors. I went back and looked at them after sitting for 6 days and the white part shrank. I don't know what happened but it shrank, you can see marks where it moved. almost like a glacier retreating. too cold when drying in my garage?
--Gregg--
Anthony
Post by Anthony »
Doors look nice Gregg... I agree with Rusty on the pan head screws... will give it a more finished look.... Glad to see some of us are making progress...
64shortbed
Post by 64shortbed »
I agree; the doors look great. I hope the paint didn't shrink too badly.
-don
'64 F100 262-I6
slickmainer
the white shrank pretty badly. It was put on over the blue, which was put on over primer. I'll have to sand the white part and just make it all blue like before. oh well, live and learn
--Gregg--
slickmainer
repainted the doors all blue. I wasn't meant to be fancy with two tone painting. I did get the gauge cluster repainted again. the Chrome paint I used wasn't holding to the plastic so i stripped it off and went with plain white. Got all my knobs back in the dash and working on the steering column paint, and the steering wheel.
I must have ADD, cause i have 3 pieces of the pie all going at the same time. doors, floors, brakes
--Gregg--
slickmainer
took a different route on the gauge cluster. I had repainted it in chrome, but it wasn't holding, so I redid it in Wimbledon white, I like it better
--Gregg--
MadMaxetc
Post by MadMaxetc »
Wow. That looks realy nice.
My Build Thread
slickmainer
thanks I was really tempted to try something new, using a gauge cluster from a 63 falcon. The gauge cluster layout is the same and it has a cool trim to it that is similar to the 65.66 custom cab, but i couldnt' find one cheap
--Gregg--
rctcomp
Post by rctcomp »
That dash looks sharp! :rocker:
Jeff
oldtrucks
Post by oldtrucks »
Slickmainer
Use the blue tape when you are 2 toning it doesn't stick real tight and comes right off and doesn't leave anything behind. Did you use the same brand og paint for the white as the blue? Otherwise just let it cure some more and re-mask and repaint at a later date.
I like the way your door looks so just be paitent and keep up the good work
Mike Kincheloe
Mikes Old Trucks
I restore old trucks and cars
1950 F7 Cab and Chassis
1976 F150 4 Speed 4 X 4
1996 Taurus
olliesshop
Post by olliesshop »
Looking Good!!!
Tim - 1961 F250 Uni
64shortbed
Nice job on the gauge cluster! I like WW better than the crome.
-don
'64 F100 262-I6
slickmainer
not much to report lately. I did finish up one door though, and got the photos of the accessory mat I bought off ebay. I need to get the other door sanded, primed, sand, and painted, then the fun task of shoving all the door guts back in it.
pass door-minus trim rubber
NOS 79 truck floor mat (not full width, this goes over carpet)
--Gregg--
ezernut9mm
Sweden
Post by ezernut9mm »
looking good greg. your screws should arrive any day now.
slickmainer
awesome, just in time for the other door.
I bought new screws for the access panel. I bought white gutter screws and the white is pretty close to the white in the dash.
--Gregg--
olliesshop
Looks nice !!! :D
Tim - 1961 F250 Uni
slickmainer
also scored the 3 volume set of shop manuals for a 1965 of Craigslist. all three for $10 plus shipping :D
--Gregg--
