Aerostar front suspension?
flgargoyle
Post by flgargoyle »
I've been reading about putting an Aerostar front end on older Ford trucks, and I wonder if it would be applicable to Slicks. Anyone done one or seen one? I was looking at them in the junkyard the other day, and it looks like it would be a simple install. The whole assembly is simply bolted into the frame. I have a later chassis w/ disc brakes, etc. for my '64 project, but this looks simpler in some ways. I'm not looking forward to pulling the cab and the bed if I don't have to.
Jay
'64 Short Wide
'96 F150 SWB 4.9 auto
mikecarson
Post by mikecarson »
Yes, Johnny Canuck did it, among a lot of others.
[img][albumimg]50[/albumimg][/img]
Mike C
64 CC, Crown Vic project
62 CC
67short 94 F150, 433W
Johnny Canuck
Post by Johnny Canuck »
The aerostar is a nice swap but it seems as though the 03 and newer crn vic crossmember is less work. All Aluminum crossmember, tubular upper & lower control arms, power rack & pinion. All you really have to do is box the frame and drill 4 holes for the crossmember and 4 more to attach the sway bar then bolt it on. They sell used for about $500 so you could likely get the aerostar front cheaper though.
jakdad
Post by jakdad »
mikecarson wrote:Yes, Johnny Canuck did it, among a lot of others.
And he has Marauder wheels on it!!! :D :D :D
Jim
Johnny Canuck
well it IS a Mercury.. :)
