I am lost. Can someone lease post a picture of where the springs and brackets attatch to the manifold. I have a 460 if that matters.
Jacob
I need help with throttle linkage springs location on dent
BackyardRest
Re: I need help with throttle linkage springs location on de
Some go off the throttle cable brkt on back carb studs, others go off a separate brkt that bolts to posts on back of intake. I will try to get pics of both. The brkt that goes on carbs studs can change depending on which carb you are using?jacobd wrote:I am lost. Can someone lease post a picture of where the springs and brackets attatch to the manifold. I have a 460 if that matters.
Jacob
Post a pic of intake and carb
