made some progress on my 66
dotcentral
Post by dotcentral »
Yesterday I pulled the motor, removed the hood, hinges, and inner fenders. The rest of the clip was already off.
Today I pressure washed the firewall, frame and exposed cross members, front suspension, etc. Cleaned up pretty good. Tomorrow I'll download photos and if they show anything I'll load them up.
I want to paint my firewall, then paint the frame and steering linkage. I was thinking brush on rustoleum, since I will not be doing the frame all at once, and I think it would be easy to touch up. I think I already have some satin black in can. Any comments on the durability of this stuff?
This weekend I need to dig up my parts tumbler and clean up some of these fasteners. Is there a good, cheap, durable, & easy to find paint anyone is using for these? I usually paint these with rustoleum as well, but the paint seems to not hold up as well on these.
When I use Rustoleum this way I roll most of it on with a 3" roller, after I get the spots the roller can't reach with a brush. The covers are dirt cheap so I just use them and pitch them. These leaves a real good coat that is very durable. One of those cheap canister $20 spray guns at Harbor Freight lays the stuff down real well too. I use their "Rusty Metal Primer" underneath applied the same way.
dotcentral
Greg, I was thinking the same thing. I used that same primer on my cab floor. Seemed to take a couple days to dry, probably because of the humidity. I need to see if I have anymore rollers. I want to paint my firewall first, then brush or roll on the frame after the firewall is done.
I thought I had some Rustoleum satin black in the can, but just checked & it's gloss. Guess I'll have to spring for a can of the satin.
I was thinking about getting some gray or silver for the tierods, steering box, etc. Although I do have some Eastwood manifold paint. I wonder how that would hold up?
Anyone know what is a good paint of a master cylinder? I tried the Eastwood manifold paint but it hasn't did so well. Or maybe it's in the prep? I'll try a web search and see what I can find I guess.
Never had any trouble getting a good coat on a MC, just never got one on that the brake fluid didn't eat, lol.
dotcentral
Got the rust cleaned up, feather out some scratches, etc.
Sprayed some etching primer on the baremetal, and then followed that with some high build primer. I got a little carried away trying to get rid of some sanding scartches and needed to go back and put some more etching primer in a few spots. That cost me an hour, which had a ripple effect.
I hoped to painting the firewall tonight. I am doing the body & paint at the local community college. By the time I fixed my mistake, another guy setup his sandblasting equipment right next to the paint mixing station. Well, don't know if he realized what he was doing, but he made a big cloud of dust in the area before I could ask him to do it elsewhere. So, not wanting a textured finish, decided to call it a night. Maybe next time.
I have added a couple of photos from Monday and tonight to my album.
Anthony
Post by Anthony »
coming along nicely dot..keep up the good work and keep us informed..... Anthony
dotcentral
Primered the front portion of the frame with the Rusoleum product for rusted metal. May have ben overkill as my frame isn't very rusted, but guess it doesn't hurt to prime and I had the materials on hand. I will eventually top coat with Rustoleum satin black.
I sprayed the bare metal with POR marine clean first and scrubbed it down. I got it cleaner but short of giving it a bath in a pit of chemical cleaner not sure it is possible to get it 100% grease free. Wish I had wore a mask. My throat is a bit irritated after using this stuff. At least it isn't as rough on a person as the POR paint.
Anyone have a decent, non-toxic, degreaser they like? I will need to get the truck up on the lift to get a few more areas a bit cleaner.
Added 2 more photos to the gallery. I need to straighten the driver's side frame horn, curled in a bit from the PO hitting something.
I guess I am done with the frame, chassis, & firewall until next week. I need to get in my garage and start using my parts tumbler to clean up some fasteners and other small parts.
64low-n-slow
Post by 64low-n-slow »
For the non toxic part I use Purple Power straight (put it in a pump bottle), let it soak then rinse with as much pressure as I can get. Then to get the grease all the way off, I spray on mineral spirits and wipe dry with clean rags.
1965fordf100
Post by 1965fordf100 »
Lookin good dot! I just finished priming part of my frame, and will be top coating tomorrow night! I feel ya on those fumes, that stuff will get ya if you don't wear a mask
Phil
dotcentral
I got back on the firewall tonight. I am using basecoat/clearcoat. The gray color is a metalic, Medium Platinum Poly, the Red is Canyon Red, both early 90's Ford colors. I have the basecoat sprayed, but had some problems with my tape job. The masking paper wouldn't stay in place so I will need to touch up gray before laying down the clear.
I will update my album tonight to show what I got done. Not a show finish, but looks like I got the firewall and cowl better prepped than last time, so hopefully it will look nice once done.
Then back to the frame and suspension painting.
I've decided to paint my engine red. Best shade of VHT I could was a Chrysler color. Hoping it will look decent.
dotcentral
Got the firewall touched up and in clear Wednesday night, but forgot my camera. The cowl part had a few sanding scratches and chips I missed :cry: , need to start using a guide coat I guess. But overall I am happy with it. The clear flowed very well and helped mask some of the probelm areas. Much better job than what I sprayed on it last year.
Once I get the engine in, the sheet metal hung back on the front, I'll see how it looks. If the defects in the cowl stand out, I'll redo when I work on the cab.
I remembered my camera today, photos in my album.
1965fordf100
Lookin good dot! sorry to hear about the tape job coming loose, hopefully a easy fix for ya...keep up the good work!
Phil
Looks good, same kind of stages I'll be painting mine in.
dotcentral
got the inner fenders painted, temporarily mounted. Engine bay portion of the frame also painted.
Need to paint the steering box, I beam, maybe the springs - not sure yet on that one.
need to mount the seals, forgot to buy staples. need to locate my 302 engine mounts also.
a copuple new photos in my album.
dotcentral
Well, finally got a few things to talk about. Tooks some photos, but I got my digital camera out of wack so they look crappy. for now at least the 302 EFI is in the 66. I'd prefer it be in the 71, and the 351 in my 66, but with the trouble I have had getting engines & trans together and into something, seems like that would be asking for more trouble right now.
Questions. Looks like the engine is sitting a little higher on the driver's side (Look at the distributor). Next week I'll try to even that out a little bit, but is that something to be concerned about? I didn't even notice until I downloaded these photos. http://fordtruk.com/forums/album_pic.ph ... ser_id=227
Oh yeah, I forgot to buy new nuts to tie the mounts to the towers. Are those 1/2" or 9/16" nuts?
Look at all this room in front of the firewall. Is this typical? If not, is it okay? Plenty of room for linkage and such I guess. I'd would hate to pull it out and relocate the engine stands unless it has to be done. http://fordtruk.com/forums/album_pic.ph ... ser_id=227
Looks like I'm fine on fan to radiator clearance, but won't really know until I get things together I guess. I did save the T-bird shroud. http://fordtruk.com/forums/album_pic.ph ... ser_id=227
I also forgot to get a trans mount, so right now it is resting on the crossmember. What are people using for mounts? I think on my 71 we were able to get a C4 mount on the 3 speed manual X-member, guess I'll have to crawl under it and look.
fianlly, I smacked the tailshaft onto the bottom firewall lip and knocked about a 1/2" chunk of paint off. it was over the undercoat, but still it is in a noticeable place. :(
dotcentral
Made some slow progress today. Hopefully tomorrow will give better results.
Picked up a distributor at pull-a-part Thursday, and bought some new sensors. Not sure which Oxygen sensors to use, 9" or 16" long. I will see how well the old ones fit and then decide.
Had a friend help with trying to swap the pins around. When he got home, he found a post about it on the Ford Fuel Injection site. http://www.fordfuelinjection.com/index.php?p=74 Didn't realize that orange thing needs to come off the plug to access the pins. I gues I could mark each wire for the right spot in the plug, pull all the pins, thread the wires through the grommet, then reinstall the wires into the plug.
I mentioned the wiring bundle being smaller than the grommet hole. I forgot I received some of the plastic wiring shield/armor. That would probably take up the difference if installed on the wiring bundle.
I am mounting my EEC (computer) under the dash. I'll need to make a bracket of sorts. I am thinking about a sheetmetal bracket that can be fastened to the brace to the between the ash tray & glove box. I have heard these need a ground. Might want to run a ground to the firewall, or will the bracket be self grounding?
The pass thru from engine to firewll is just below the heater box. I think it is high enough to not get kicked, will get some protection from the heater box, and hopefully let the wiring to the AOD reach without needing to lengthen them. It needs a 1.5" x 3" stretched out circle-like shape. I drilled pilot holes, but my hole saw bits need a drill with a 1/2" chuck, so until I can borrow one, that part is on hold.
I need to get a new belt tensioner. New they are about $70 around here. :shock: Thinking abut hitting the junkyard for a used one.
Looks like the oil pressure sender interferes with the driver's side accessory bracket. I'm not going to run power steering. Maybe I should move the a/c to the pass side and free the driver's side up? I am a bit confused on bracketry. Maybe I should cruise the junkyard and look for setups to try and copy.
Hope this isn't boring anyone. I am looking forward to getting this thing back on the road. It has been about 20 months since it ran on it's own power.
not boring me.
they do make 45s and 90s for the oil senders. find one in a junkyard or hit up the hardware.
i would think that if the puter was attached with a bracket to sheet metal originally and had no extra ground wire that it was grounded thru the bracket to metal.
Thunderboy
Post by Thunderboy »
Not sure if I missed it or not, but are you using the correct small block engine to crossmember mounts? I think the 70-up Bumps and Dentsides used a small block mount that lowers the engine a bit. If you had a six cylinder in it, the engine is further forward and higher than it needs to be. There is info about this either on this site or maybe Fordification.com (I can't find it right now).
I am reading your work with interest, Dot, as I am doing an EFI Windsor myself, and am daunted by the wiring. Nice work! :D
dotcentral
I have the correct mounts. They are shorter and mount in a different position than the FE and 6 cylinder mounts. My engine is sitting a bit lopsided, but I can adjust that when the time comes. Actually, I need to remember I don't have it bolted down yet. The engine is sitting on the stands, with no nuts on the motor mounts.
dotcentral
It took a few days, but I got an email back from RJM on some questions I sent them. They said to cut the grommet to get it on the harness. Seems like they could have built it into the harness.
I found the right water temp sender. Still need to figure out my oil pressure sender hook up.
For new news, when I cut the hole for my grommet and to let the computer wiring pass thru the firewall I messed up the paint on the firewall. Not right away, but a comedy of errors.
I cut the two 1.5" holes, trimmed the area between them, all that went okay. then I filed down the burrs left from that, which went fine as well. I decided to paint the exposed sheet metal and it went down hill fast.
I should have used a paint brush and carefully painted the bare edges, but thought I could tape things off and use a spray can. The paint ran under my tape, so I wiped the runs off the firewall with lacquer thinner and tried again.
I re-taped and the combination of softened paint from the lacquer thinner, retaping and rubbing the tape down hard to prevent bleed, through caused a section of the paint to lift off the firewall when I removed the tape. :oops: That area may not have had good adhesion to start with.
No photos, I forgot my camera. I touched it up this time using the original S-W metallic silver mixed with some clear and painted on with a foam brush, looks half a$$ed. I need to order a can of that color silver in a touch up kit and try again.
1 step forward, 2 steps back. I did swap in the correct distributor for this harness, and get a few other minor things done as well. Never goes as fast as you think it should though.
