Hey Everybody,
We're putting a fuel-injected 460 out of a 1989 E-350 into our grandaughter's 1964 F-100. I know there's wiring harnesses out there that you can buy, but they're a bit too much for our budget.
Has anybody done a similar build--on a budget--and how did you wire it so to keep the fuel injection?
Wiring a Fuel Injected 460
patsroamin09
- Alan Mclennan
- PFM-64f100
If you grab the EEC (computer) and wire harnness then it is fairly simple. Now most of the FI 460 are Bank Fired and use speed density instead of Mass Air. A really good resource for Ford FI is http://fordfuelinjection.com/?p=1. They should have a drawing of the pin out for you or at least get you really close to it. You will have to wire in power and some realys (unless you can harvest those) but it's easier to wire in new ones. The 88-92 EEC IV computers are fairly simple at least compared to the ODBII computers. Check out there wire harness for the 4.6 and you will see what I mean.
They also have a great little wire harness for $475 I think. It is a mass air setup for the 5.0 mustangs but can be modified for your application. But if you get that you might as weel convert to Mass and chip the EEC. I plan on using motes QuarterHorse http://www.moates.net/product_info.php? ... cts_id=199 or use the tweecer (just google it).
Also check out http://www.460ford.com/forum/ if you don't already know about that site. They have some good info on the 460...
I will be converting my 64 with the 460 in it but since it's a dove block I am modifing a manifold for the FI. I do a little work on that project everyonce in a while. Take a look at bigblock ranger's site and it will show you how I am converting my intake. http://bigblockranger.com/Intakeconversion.html
- PFM-64f100
Thanks I hate it when my fat fingers get off track or is that the mind getting out of sync... humm ... I went ahead and updated it to be correct...62galxe wrote:help you with the link chris.
- in2hotrods
- PFM-64f100
Fairly new they were added to there catalog on Friday 20 February, 2009in2hotrods wrote:PFM,
I knew about moates.net but hadn't heard of the QuarterHorse...is it new?
it looks like a very good product.
turtle1056
it is very easy to use the entire wire harness from the 87-91 F150,250,350 truck and by doing so you get rid of the old glass fuse setup, get newer switches intermittant wipers, cruise, tilt, etc etc
Just take your time removin the harness from the cab of the donor truck, label everything, and it will go back into the slick just about as easy.
Heater and wipers take a little fiddlin because some of the wiring from the donor runs through the firewall and needs to be brought back inside
My truck is one step further - we used the entire frame and drive train from the donor so we had updated everything
Its a "slick" setup pun intended
