My New Bumpside!
My New Bumpside!
Well I just buoght a 1967 F-250.
<Link To eBay Auction>
The truck is realy solid. It has some rust on the floor, but it is on the flat portion so it is an easy repair.
I am stoked about it and will be asking questions over on Fordification I am sure!
NO, this will not take away from my 63. I bought it to replace the 73 witch is rusted out VERY VERY BAD!
It has a 360 but it has a burt valve. Anyone need parts? I am going to put the 300 in it. So I won't need the 360.
Well guys I will post more latter!
ClanCassidy
- Hoofbeat Racer
That looks like a pretty nice truck Dan, congrats!
- 66fordtrucknut
- Truckfarmer
- Johnny Canuck
Nice truck, Dan!
Those old bumps are kind of the epitome of "Ford Built tough" I still see a half doz or so every day being used as work trucks.
I had a '72 F-250, unfortunately the body on it was beyond saving and it had a 360
in it. That baby was fun to steer with no power steering!!.
I was looking for a shortbox Mercury Bump, when I found my first Slick. Shortbox Mercs are like hens teeth, and I ended up with my '64 LWB, but I will always have a soft spot for the Bumpsides, especially the 67-68 Mercs.
Have fun!
JC
Have fun!
JC
Is that how much you paid? $200?
The auction sez it didn't meet reserve, I'm assuming you worked out a deal afterward?
Looks like a good truck, though.
No I didn't pay $200 for it. The guy is local and he had his resurve set at $2000
but the buy it now was $1800, whatever...I got it for $1400 because I was/am a Ford guy. He said he was hoping some guy didn't buy it and put a cheby in it.
I am goin to go get it on Friday...I am so stoked!!!
Well Here was my original thoughts on what I wanted to replace my '73...
My thoughts where as follows...
So here are some questions...
Thanks for your help and support guys!
- '65-'79 F-100/150
- Engine in any condition (including gone)
- Any conditon manual trans
- SOLID AND VERY RUST FREE!
- REALY good 300 I-6 and 3-speed (in the '73)
- A 9" out of a '75 with 3.70:1 gears
- 2 sets of front Disk Brakes
- An automatic column (short) from a '75
- a Saginaw P/S box and pump from a '73
- And the '73 has P/B.
- It has solid cab mounts and the bed is in great shape
- the frame is the same as the F-100/150s
- The engine and rear end could be sold off
- It has a 4-speed on the floor
- Fix the small rusty spots in the floor and sound deaden and insulate it
- Re-build a set of I-Beams and Disk Brakes from an F-100/150 and put them on
- Take out the Dana 60 and put the 9" in, but keep the 250 springs for the ocational load
- Check wirring and wire for DSII
- Swap the Power Brakes over
- Swap over the 300 and 3-speed on-the-tree
- Can I use the 9" from the '75 under it with the 250 springs?
- When I do the I-Beam swap should I use the linkage for a '67 or a '75?
- Is this not going to be a bitchen ride!
Sounds like you've got a pretty decent list going there. It's funny to me, I don't hear of someone going from a V8 to a 6 very often...usually always the other way around.
But if you've already got a good 6 banger, you've got nothing to lose.
Congrats, the price sounds good too.
- Truckfarmer
Nice score! I think you have a very solid plan and I agree with you on the 300. I would probably use the SROD 4 speed OD behind it.
Personally, I would install the power steering while I had the engine out of it. It would be much easier as you can climb in there with it.
- Johnny Canuck
Good for you Dan.. sounds like just the ticket. I agree with Greg on the power steering, and the Six. I could barely afford to start that gas-sucking 360, never mind run it anywhere, so it sat. A LOT. I think I checked it every time I ran it for a hole in the gas tank. Couldn't believe a truck could burn that much gas.
The spring locations on the '75 are wider apart than the '67, you will have to move the spring mounts in a little bit. The axle width itself is wider too, shouldn't be a problem unless you were gonna run some big-offset meats under the bump.
At what point did 3/4 tons all have front disc brakes? I know they were standard way before most trucks even had them installed as an option.. just not sure what year of bump that started on..
JC
JC
OK, so are you saying that the spring towers are wider apart on the ’75? If so, by how much? If it is an inch or two, will the springs still mount OK? Or should I use the I-beams off the ’67 and the spindles off the ’75? The beams on the ’67 are 250 beams and the spindles from the ’75 are from a 150, so are the King Pins compatible?
I need to know so I can explain it to the machine shop. He knows his stuff, I just want to explane it so he doesn’t think I am an idiot!
I can do whatever, I just want to make sure I get it right.
Thanks Again for the help!
- Johnny Canuck
Dan. Re: I beam swap, use Dwights or the Fordification how to's.. I think you need to stick to all one year for the steering rods, beams,springs, radius rods, etc etc. but I haven't got an I-beam truck so those guys are the ones to ask/read.
The front frame width is the same in a 73-79 truck as they were from (I think) 53 up so the coil spring towers are the same distance apart, 65-79.
the '75 frame gets wider BEHIND the cab, so the back springs are +- 3" wider apart, and the axle housing overall length is increased by the same amount. So you need to move the spring perches on the '75-9" axle housing inboard about 1-1/2" each to fit the '67. Do your own measurements don't go off my generalizations.
JC
JC
