460 overheating
460 overheating
i put together a 460 for my boss last summer he wanted it done cheap. so all it got was new rings, bearings(rods and mains), cam and intake. since then it will overheat in a matter of 5 min or less and oil pressure will drop from 40 to 5lbs at idle. the motor acts like it is going to lock up. let it cool down then it is back to normal for another 5 min. any help would be great
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
c-6 wide ratio modified
torino front stub
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
- Falcon Interceptor
No I can't help but did you try the obvious? Is it the engine or radiator? Did you try it without a thermostat? Is the water pump pumping?
Sounds like you might not be cooling at all - would have the same effect with no water in it. Also just because it has water, doesn't mean it's circulating.
I had a similar experience the first time I fired up a fresh Y-Block, the thermostat didn't open and it overheated immediately.
Last edited by Falcon Interceptor on October 1, 2009, 8:13 pm, edited 1 time in total.
Head gasket? The oil pressure thing could be from it getting too hot, a tight engine will get tighter when it gets hot as you know so that is the wanting to lockup when it's hot.
when the motor was first put together the thermostat was gutted and i put in a new one to day and no luck will check for circulation tomorrow. was also wondering if head gaskets were different from year to year maybe blockage from wrong year?
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
im pretty sure they are on right
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
