460 overheating
Posted: October 1, 2009, 6:48 pm
by aarons428
i put together a 460 for my boss last summer he wanted it done cheap. so all it got was new rings, bearings(rods and mains), cam and intake. since then it will overheat in a matter of 5 min or less and oil pressure will drop from 40 to 5lbs at idle. the motor acts like it is going to lock up. let it cool down then it is back to normal for another 5 min. any help would be great
Posted: October 1, 2009, 8:07 pm
by Falcon Interceptor
No I can't help but did you try the obvious? Is it the engine or radiator? Did you try it without a thermostat? Is the water pump pumping?
Sounds like you might not be cooling at all - would have the same effect with no water in it. Also just because it has water, doesn't mean it's circulating.
I had a similar experience the first time I fired up a fresh Y-Block, the thermostat didn't open and it overheated immediately.
Posted: October 1, 2009, 8:12 pm
Head gasket? The oil pressure thing could be from it getting too hot, a tight engine will get tighter when it gets hot as you know so that is the wanting to lockup when it's hot.
Posted: October 1, 2009, 8:37 pm
by aarons428
when the motor was first put together the thermostat was gutted and i put in a new one to day and no luck will check for circulation tomorrow. was also wondering if head gaskets were different from year to year maybe blockage from wrong year?
Posted: October 1, 2009, 8:50 pm
by 36truck
Head gaskets on wrong front to back?
Posted: October 1, 2009, 9:03 pm
by aarons428
im pretty sure they are on right
