No heat
No heat
Any of you own Explorers from 95-01? I have a 99 and just about the time we are needing the defroster and heater, it has decided not to put any heat out. I checked the little heater control valve on the heater hose today, and it appears to be opening and closing ok. The vacuum on it only works when you turn the heater off so it will close. I even tried opening and closing it manually to see if I am getting circulation through the lines and had Marla sit inside and check if it blew warm air. Stayed cold whether it was on the defrost, dash, or floor setting. Only thing else I can think of is if there is a blockage somewhere in the heater hoses. Any ideas, guys? Was hoping some of you might have had this come up and if so, what did you do next? TR
ezernut9mm
Sweden
Post by ezernut9mm »
i know the rangers in those years had the same type problem. it was a control module behind the glove box and it was a mechanical problem if i remember. like the part wore and stripped out to where the control arm wouldn't actuate the baffle to allow the heat into the cab.
maybe the explorer is the same design.
i found this out on a ranger forum for a friend. i can't remember which one though.
ezernut9mm
Sweden
check out this gary. it's called the "blend door" and it is a problem on many models in those years.
http://www.ford-forums.com/heating-air- ... -heat.html
Michelle
Post by Michelle »
It is probably the blend air door. Check the vacuum to the blend air door. Either no vacuum or the diaphram is busted in the vacuum motor. I had the same problem once on a Lincoln.
Michelle
had that issue in my 82, ended up baling wiring the door open. :cussing:
you never have that problem in a slick
f100jim
Post by f100jim »
I've got a 98 ford exploder,had the same problem. the blend door was broken. The dealer said to fix it I had to replace the whole box under dash !! Me being frugal or tight (what we call it around here) fixed it by cutting the pie shaped indention where the door pivots, out on the bottom of the box cutting it on an angle so it would pop back in place, pulled out the broken flapper door and repaired it .Works great , has for 3 yrs. jim
No heat
Thanks to all of you, I knew there had to be some around here that had "dealt" with this problem. TR
