My neighbors got a new van and sold me their 97 plymouth voyger for 200.00. It shifts back and fourth between 3rd and overdrive I think. if you pull it down in 3rd and drive it there its fine but tacks out at 55.
they said they had it fixed once (rebuilt i think)
Heres the deal ...Its solid in the gears another words its not slipping and once in a while it will shift out fine then for no reason it starts alternating between 3rd and OD.
Im thinking its a modual of some sort.Whatever tells it when to shift has gone out. If you have any input it would be appriciated. for 200 bucks I will drive back roads for 10 miles to work in 3rd and money ahead.
If i can fix it I plan to sell it for what I have in It to my nephew who needs a way to work bad to support his little redneck kids.LOL
Question about a plymouth voyger mini van shifting bad
- 65f100_Thug
i would first try speed sensors if no luck try solenoid pack
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
c-6 wide ratio modified
torino front stub
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
- Johnny Canuck
Push it in the lake, they should have paid you $200 to take it.
seriously, check the TV cable. Chrysler schmit transmissions fry up when the TV cable is out of adjustment. Or any other time.
P.s. I have nevr met ANYONE who had a chrysler van that didn't have transmission problems. or head gasket problems. or both. Those things are the single worst POS on the road, bar none.
