Non slick question on a engine. My daily driver is a 91 Mazda b2200. I am hoping to get a replacement in the spring so I am trying to just get it to last. It has a aftermarket webber carb on it. It sometimes jerks at times but not often. It does it usually when it is coasting in slower MPH areas. Its like the rear end gears are spinning faster than the automatic transmision or engine. Its like it trys to make them go faster.
Anyway here is the issue I had this morning. I had started it last night to make sure it would start this morning, frost was predicted. It run rough but I figure it would be due to it being a carb. So this morning I get out in it and warm it up a few minutes then took off and down a side road I use to get it even more warmed up. I get it out on the road and it run rough a lot more than usual. I almost thought it was going to quit a few times. I could take it out of overdrive and it would run good but slower. I would have to give it gas. I get on the interstate and it ran fairly decent at 60 and better. Well I get it to the exit and go to the gas station and turn it off. It backfired and a big puff of black smoke came out. I get in it and it runs decent the rest of the way to work. I get out and pop the hood. The transmission fluid is up like it should be. The one thing I notice is water or condensation is everywhere. The carb had a lot on it, I checked to make sure it wasn't gas. As far as hoses they all were on and I have changed them all as well. So I am figuring it may be the condensation. I did not run it other than to start it last night and I ran it some Friday but only around the house. It also got cold enough to frost last night as well.
My question is could the condensation cause it and if so what can I do to keep from effecting it so much. I do park it under a carport that is open on the sides. I have wondered if just opening the hood up at night would help. I am not looking for a major fix just one till I can trade it in.
$#$#@!@ daily driver
fmartin_gila
fmartin_gila
Just happened to remember, Quite a few years ago, I installed a 32/36 Weber on a Courier(predecesser to the B2200). I may still have some info laying around as to the setup and adjustments. I can try to dig up if you need. Also search Weber Carbs, they have a website that covers all the info too, May be Redline.
Fred
Fred
