front leaf springs
gasser vince
front leaf springs
Post by gasser vince »
i need a set of front leaf springs for my 1964 f100 .anyone know if i can use anything other than fords maybe something universal
61-64 are all the same. You can get stock reproductions, reverse eye mono leafs which lower it, and I think a regular eye mono leaf which also lower it but not as much as the reverse eyes. If there is a spring shop close to you they should be able to build you a set to about any specs you want.
BTW, what's wrong with the ones you have?
Gary Seymour
Post by Gary Seymour »
If you just need springs to get you going, some one on here might have a used set they'd part with.
