Anothter Near Fatal Mistake
Michelle
Post by Michelle »
My 56 F 100 has a four link triangulated suspension under it. The right panhard rod had broke the weld loose from the right frame rail. After the weld repair I was ready to put the panhard rods back in. While it was down, I ordered new bushings for them and started back in with them yesterday. The rear of the truck was jacked up with two tall truck stands supporting the rear axle housing. I had to jack up the rear of the truck frame to get the body weight off the axle housing so I could get the panhard rods into position. My floor jack would not go high enough to lift the rear crossmember because of the high truck jack stands under the rear axle. I used a eight inch 2X10 between the jack and the rear crossmember to get the extra heigth needed. All was going well until the truck rolled forward with me laying under the rear of the truck with the pumpkin right over my chest. The axle was still touching the jack stands but unknown to me was the fact that all the weight of the truck and the axle was being held by the floor jack. The truck rolled forward, tilting the jack stands forward and then rocking back before finally coming to rest still firmly resting on the jack stands. I had my left leg pulled up with my knee up and the fuel tank hit my knee, skinning my knee, but not breaking my leg. I thought for a moment it was going to fall right on me. After I regained my composure, me and the creeper rolled out with about five years scared off my life and skid marks all the way to my ankles. By the way after taking a bottle of nerve pills to calm down I chocked both front wheels
Michelle
Michelle,
stuff like that is enough to turn all your hair white overnight.had plenty of my own experiences like that over the years.
i am very glad to hear you are ok.
Max
Post by Max »
Glad to hear you're ok!
Brian Taylor
Post by Brian Taylor »
I lost a car buddy of mine 3 years ago from a similar incident. His wife came home to him under the car. I am soooooooooo gald that it caught the stands. I did see how the truck was up when we were there Saturday.
Michelle you needed a few wet wipes after that. I did notice that your shop was big enough for a nice lift. Ito make life easier, safer and longer.
Hope your nerves are good now. Brian
1966 Ford F-100 LWB 300
stronger66ratfink
Post by stronger66ratfink »
da..am Major, I've already been to one funeral at Arlington for a family friend this century, impressive but don't want to attend another!
Glad to hear your OK!, and another item for Thanks Giving!
thrush544
Post by thrush544 »
AMEN!!!
Roger Carter
Post by Roger Carter »
Glad you are OK.
I too have been down a similar road. Now, when a rig pulls into the shop the first thing I reach for are the wheel chocks.
Hope this is a lesson for all.
Roger Carter
Obsa
Post by Obsa »
Glad you were not hurt. You know sometimes we all need a good scare to remind us that there is always time to make the work area safe. Betcha the wheel chocks will the first thing you do next time. Once again glad you are Ok
macgiobuin
Post by macgiobuin »
Wow! Glad to hear that you are OK.
My Baby: 1966 F100
Michelle
Post by Michelle »
I have always been a person that tried to learn from other peoples mistakes, I have found it to be a lot less painful. However from time to time I have had to learn the lessons the hard way. I thank the Lord for being under the truck with me and allowing me to live to tell others of my mistakes. Yes, the wheel chocks will be installed from now on.
Michelle
Phil
Post by Phil »
Makes me pucker up just reading this.
I did a similar thing this summer.
Had the Mustang on stands and in gear so it wouldn't roll (still an E-brakeless project car)
I was under it and dropped a wrench on the starter. It made contact and rolled the car fwd as it turned over. Thank God I put the jack under the X member in addition to the stands.
Now I undo the battery even when I add wiper fluid :lol:
Glad to hear your number wasn't up- I enjoy your posts and (less exciting) experiences
I dropped a 71 Camaro on myself once. I was wrestling on the rear axle with it up in the air. Car started to rock pretty bad so I rolled out as fast as I could. On the way the car fell just in time to catch my right arm between the rear splash pan and the gas tank - snapped the bones clean about 1/2 way between my wrist & elbow. My Dad turned an interesting shade of green when I grabbed my wrist and set the break right in front of him. Hey- it was flopping and that hurt; made sense to me. :dontknow:
Anyway you look at it I was very lucky - you know how it could have ended.
Michelle - be careful there, everybody else too.
Uncle Skip
Post by Uncle Skip »
Michelle.
Your tag line "with age comes wisdom" is most appropriate.
But sometimes even us "seasoned, experienced" troops have what I call a brain fart.
And those lapses can be terminal.
I'm really glad you dodged that bullet.
Folks.
Stop, take a good look at what you're doing, and if you're not 20 years old, think about what it will take for re-hab if you screw up and cut corners with safety.
If you're 20, you aren't going to listen anyway. You're still bullet proof at that age.
Remember, us old farts don't heal like we used to do.
Thank you God for sparing a good friend from a very serious situation.
Uncle Skip
Casey 65
Post by Casey 65 »
Michelle, I'm glad you are OK. We all know the "safety first" rules, but in the middle of a project... Uncle Skip is right.we all make a mistake that could have very unplesant results. WE ALL need to take that step back and ask ourselves, "what the heck am I doing!"
61 Merc
Post by 61 Merc »
Glad to hear you are okay, just had a funeral yesterday for a co-worker who had a part crush him as he was working on a tractor. I don't think he was even under it.
Dean
61 Mercury SWB Uni - Project
63 Ford SWB Uni - Parts truck
ABA
Post by ABA »
How long you been turning a wrench?
I always chock a vehicle no matter if it's on a ramp, jack stand or a jack and I give it a good shake or a bump before I get under it.
This reminds me...I need some of those nice rubber chocks....I'm bad about forgetting the vehicle is chocked and I run over them....gone threw a few sets of those fold up chocks that come with a jack.
Glad your lesson wasn't as painful as it could have been Michelle.
'01 F150 Lightning
490RWHP
Gas Mileage? What's that?
Jerry
The Big M
Post by The Big M »
^Absolutely. I'm totally paranoid about such things.
Glad you're okay Michelle, and kudos for posting even though I'm sure it was more than a little embarassing. It should serve as a reminder to everyone to take safety seriously.
Take care in your shops and garages, Slicksters!
dotcentral
Post by dotcentral »
Like others have said, I chock at least one wheel on the opposite end, then give a vehicle a firm shake before crawling under anything on jack stands. I like to stick the tire(s) I removed, if any, under the vehcle as well. I didn't use to do all that, but have heard too many bad stories over the years. I try to keep my cell phone in a pocket or close by also. If I get pinned somehow, hopefully I can get to it and call for help.
A friend of mine had his neighbor get crushed to death last year. The guy was using a engine hoist to lift up & hold a mower deck to work on it. Apparently the lift cylinder developed a slow leak and the guy got trapped and slowly crushed.
winr
Post by winr »
Hey Michelle.
Glad you are ok and will live to fight another day...
I had a 66 Dart GT slowly keel over on me when the jackstand started sinking in the ground, it was on a piece of plywood..but..eh...I was 15 and Immortal.
The 273 was running as I was checking for an exhaust leak, the muffler started pressing against my chest and I tried to press the car up as I was pushing myself out from under it.
My shirt was ripped off in the process and I sustained some scrapes and burns also...
Dotcentral, that is sad aobot your Friends Neighbor.
I used to work on 40,000 pound forklifts and lathes that could thread oil pipe larger than 24 inches.
The top of the lathes weighed eleventy billion tons...
The word was "Never get under hydraulics".
I am very careful since the skin and shirt removal incident..but a fresh reminder is always welcome.
Ricky.
All your Slicks are belong to us
