Mounting door panels
ClanCassidy
Post by ClanCassidy »
Hi everyone,
I'm getting to mount new door panels in my truck which did not originally come with them. This means I need to drill holes for the mounting clips to go into :shock: The idea of drilling into perfectly good doors is a bit alarming.
My plan is to remove the clips, put a small dab of blue silicone where they go on the trim, push the new panel against the door leaving blue spots on the door. I'll then drill a hole at each blue spot and mount the panels.
Anybody have a better idea ? I really don't want to screw this up. Also, anybody know what size holes I should be drilling ?
thanks.
John.
"Honest Honey, this should be the last thing I need to buy for the truck".
jakdad
Post by jakdad »
You're probably being far more accurate than Ford was. :lol: :lol:
Jim
BigTim
Post by BigTim »
Press the panels against posterboard and then make a template to use for drilling your holes out of the posterboard.
