project "BB-32"
fire truck
project "BB-32"
Well I figured I'd kick this off since I've been piling up the parts. I was going to stick with the 300 in this truck, but then I picked up a 97 7.3 and auto trans for 220 and a case of beer. I was going to build a rat rod with it, but I can get more use from this.
I plan to bag this truck, but keep it 8 lug.
I'm ditching the twin I beams, no matter what.
I'm kicking around the idea of putting the truck on a 94 GMC 2500 chassis I picked up since they are easier to bag and lay frame.
Another chassis I'm considering is an 05 2500 express, its coil overs and 4 wheel discs.
Another option is selling this truck and building a custom crew cab with suicide rear doors. if the market was better I would do this...
uhhhgg decisions.....
ebentraywick
that would be me.ebentraywick wrote:keep the frame and truck sounds like u cant get a bettter deal.. sounds sweet. does anybody ever think about lifting not lowering
i have an attachment to move snow, dont want to do it with my trucks bumper.
also with the road conditions here a lowered truck would last 1 day with bottom being scraped off.
fire truck
fire truck
Well, I took off in another direction.
I'm basing the build on a 2002 GM truck frame. Using this frame will allow me to have suspension better suited to what I want to do. I'm going to keep it 8 lug, so I figured out how to use 98 2500 spindles on the 02 frame. I have to cut a cross member out of a f250 to mount the 7.3 and weld it in. I sourced a rear from an 05 E-250, 3.73s. I'd like to run wide rear wheels and tires. Really want stock style wheels, screw all that bling... I'm going to do a short stack too I want to try a miter cut that barely pokes out of the bed...
The cab is getting some changes too...
The whole underside of this thing is rotted out, pans, supports, mounts, all of it...
I'll use the GM floor and 6 mount points instead of the four factory ones. Will be using some donor truck fire wall parts too. I want to drop the floor pan in the rear some for more leg room too, the new frame will allow for that...
thenephilm
thenephilm
fire truck
I've got a 65 f100 sitting on a 03 2500HD 4x4 frame with 35" tires... It almost fits, with the right offset it would fit. The 2500 is about 4" wider than the 1500. Good luck with your project sir...
ICEMAN6166 wrote:that would be me.ebentraywick wrote:keep the frame and truck sounds like u cant get a bettter deal.. sounds sweet. does anybody ever think about lifting not lowering
fire truck
ebentraywick
[quote="fire truck"]Relax guys, the 350 crew is getting a super duty 4x4 chassis and at least 38s....If every truck was the same, what would be the point?[/quote
Well sounds good. do u have pics of your f350??
owning a slick.,,, priceless
1961 ford f350
1959 ford f100. not a slick but still goood looking
1961 ford f350
fire truck
ebentraywick
