292 yblock pully question
Slick292-Y
Post by Slick292-Y »
I am building a 292 yblock for my resto f100 project, and I'm looking to use a double pully instead of the stock single, so I can add AC. Does anyone know if I am going to run into any issues with this? I heard something about needing to compensate with a different flywheel for balaning purposes...
oldtrucks
Post by oldtrucks »
No balancing issues, just finding one that will fit might be a problem. If you find a pulley that fits but the bolt pattern is wrong just use the original pulley as a pattern and re-drill your new one.
Mike Kincheloe
Mikes Old Trucks
I restore old trucks and cars
1950 F7 Cab and Chassis
1976 F150 4 Speed 4 X 4
1996 Taurus
Scroll down just over 1/2 way at this link - NEW correct Y block double pulleys.
http://www.ford-y-block.com/accessories.htm
Post by Gritsngumbo »
Greg D wrote:Scroll down just over 1/2 way at this link - NEW correct Y block double pulleys.
Not cheap, but it'll be right!
