I'm going to post up a pic of my grade-C condition '66 Shorty, which I'm tinkering with as my newest project so you guys can get an idea of what I'm working with.
First, does it appear to you that the truck has been lowered at all to your eyes, or are we just seeing the effect of saggy springs? I'm currently running 15" wheels and 245/60r15 tires, to give you a perspective. The rear has 5 leaves in the leaf pack, not including the upper "helper" spring. Seems like I have about 4" of uptravel from the bumpstop to the axle tube back there. In the front, I can't tell if I have factory coils, or modified, or what. I seem to have about 2" of uptravel from the bumpstop to the I-beam arm.
Second, I'm curious if you can tell me, knowing what you now know about the height (which I'll lower a bit if I move the ride height at all), what the tallest and widest tire I can fit without rubbing. I was going to use wheel adapters and bolt on some 18" wheels I have already, along with some 235/45r18 used tires that I own (about 26.5" tall), however, I'm also able to get a smoking deal on a set of wheels and tires in 20" size (brand new).
I don't want to have rubbing issues, so I thought I'd ask the experts who have done a slick up with tall wheels and lowered it what I should be looking for size-wise. Eventually I'll be doing a Lincoln/Crown Vic style front end, however, I'm not going to spend the time to do it until a year or so out.
Thanks,
Kevin
KevinsOffroad.com (we build Jeep parts for a living)
