No more Eeeewwwwww.......
ABA
Post by ABA »
I finally got the 429 pulled out of my '71 today.... should have been installed by now but mother nature just won't cooperate but today was pretty nice.
Anyways, I found this :shock:
I had all ready planned on replacing all the freeze plugs. Oh and the other side was the same but not as bad.
I'm sure the engine is going to need a good flushing out now.
'01 F150 Lightning
490RWHP
Gas Mileage? What's that?
Jerry
:shock:
never seen any quite like that before.
Max
Post by Max »
Be careful taking those heads off. One of these might pop up and nip your nose!
ABA
Post by ABA »
Crap, now I'm really worried if Iceman hasn't seen anything this bad.
I should have scrapped it off but honestly, I was afraid to touch it. :o and looks like Max knows why. :lol:
'01 F150 Lightning
490RWHP
Jerry
Uncle Skip
Post by Uncle Skip »
Dude.
That is ugly.
I think I'd rather take a nekkid shower with Joy Behar and Rosie O'Donnell that deal with that.
Seriously, you need to pull the motor apart and have the block boiled and checked.
I'd never try to flush and run something like that.
Uncle Skip
I'm with Skip.
If you don't have the scratch for a full rebuild and the engine is in good shape you should be able to "freshen it up" by cleaning it up, honing the cylinders so the new rings will seat and going through it with a standard size rebuild kit.
dwbr
Post by dwbr »
im with skip, have that block boiled and checked , will save you alot of headaches down the road
________
buy no2 vaporizer
ABA
Post by ABA »
Ok got a question, why is this substance bright yellow?
Just removed it with a scraper and the freeze plug appears solid, it's like this yellow substance seeped around the edges of the plug. Could this some type of sealer?
'01 F150 Lightning
490RWHP
Jerry
dwbr
Post by dwbr »
im guessing radiator stop leak, and if that is the case you will never get that stuff flushed out, you need to boil it
________
Corolla E70
fmartin_gila
Post by fmartin_gila »
Yeah, it does kind of look like the stuff sold as Kopper-Kote or Copper-cote some years back. Don't know if they still sell that yuck or not.
Fred
fire truck
Post by fire truck »
Looks like stop leak to me. If looks okay other than leaking freeze plugs, I'd put new freeze plugs in, flush it and run it.
ABA
Post by ABA »
fire truck wrote:Looks like stop leak to me. If looks okay other than leaking freeze plugs, I'd put new freeze plugs in, flush it and run it.
Talked to one of the fork lift mechanics at work, he's also an auto mechanic on the side and that's pretty much what he said.
I'm going to knock out the plugs this weekend and see how it looks on the inside.
'01 F150 Lightning
490RWHP
Jerry
ABA
Post by ABA »
Well got the plugs out and the back 2 were about paper thin. Guess that explains the slow seepage.
Had quite a bit of rust build up behind those 2 plugs too. Guess the PO didn't believe in anti-freeze.
I was able to flush the rust particles out with the garden hose on high pressure.
As for the yellow gunk, my buddy said it was probably a chemical reaction of the rust and antifreeze being that it was leaking so slowly.
There was no yellow gunk in the block. That's what I was worried about.
I'll install some pretty brass plugs tomorrow and try to get those 2 manifold bolts I broke out. Gosh darn it. :roll:
'01 F150 Lightning
490RWHP
Jerry
Sounds like you got lucky - COOL!
ABA
Post by ABA »
Ok, got the pretty new brass plugs installed.
Boy do I love going to the parts store....
Hello, may I help you?
Yes I need some 1.5 brass freeze plugs.
What year?
Pick one.....that messed her up.
What are they going in?
A 429.....messed her up again.
Computer says we don't have any.
But the store I just left said you have 10 in stock.
She leaves the counter and comes back in a few minutes with a handful of brass freeze plugs.
Hmm I said, guess your computer was wrong. :roll:
Got the 2 broke bolts out. One was broke at the head....no problem.
The other one broke off flush with the manifold....problem.
I drilled it for a EZ-out, heated it up and soaked it in PB Blaster.....wouldn't budge.
Got a punch to try to break the ex-out out but to no avail.....then I remembered my Dremel and I had one grinder bit for it.
That worked. Got the piece out, drilled out the bolt and retapped the hole.
She's good to go now.
Then I removed the motor mount towers, power steering box and steering column from the '71 and started removing the core support bushings but my back said enough was enough. :o
All in all it was a productive day. :)
'01 F150 Lightning
490RWHP
Jerry
