Stock Speedometer to T-5
Posted: March 30, 2010, 3:48 pm
by Nick64Slick
anyone know the best way to make the stock speedo work with a T-5 out of an 86 Mustang? I don't have the stock cable or the T-5 cable.... I've heard of people splicing the two together but would like to see if there is a cable I can buy that will work at both ends.... I know thats probably too good to be true, but just wondering if anyone has any suggestions.
Re: Stock Speedometer to T-5
Posted: March 30, 2010, 5:03 pm
by Hawkrod
Nick64Slick wrote:anyone know the best way to make the stock speedo work with a T-5 out of an 86 Mustang? I don't have the stock cable or the T-5 cable.... I've heard of people splicing the two together but would like to see if there is a cable I can buy that will work at both ends.... I know thats probably too good to be true, but just wondering if anyone has any suggestions.
I make a Ford Mustang T5 to Studebaker conversion that I sell and we use stock late 60's Ford truck speedo cable so you should be a usable stock one for your truck. Hawkrod
Posted: March 30, 2010, 6:10 pm
by Nick64Slick
sorry Hawkrod, didn't quite get that last part.... so you're saying the stock truck cable should go directly into the T-5? or are you saying you sell a conversion that will work? sorry for the confusion
Posted: March 30, 2010, 7:08 pm
by BlueGhost
I'm pretty sure Ford uses the same speedometer cable gear drive on the C-4, C-6, FMX, AOD, and T-5. You should be able to pick up a stock cable for you truck and use it with the T-5.
Posted: March 30, 2010, 8:55 pm
by charliemccraney
I am using the same cable I was using with my 3 speed with my T5. Your stock cable should work.
Posted: March 31, 2010, 8:19 am
by fmartin_gila
On my 62, the first change I made was to go to the 63 3sp trans to get the 1st gear synchro. to use the 63 trans, I had to get the cable for a 63 & up as the trans end was different. Then when I went to the T5 Trans, I kept the 63 & up cable, as it was the same. I would think if yours is a 64, your stock cable should work. Check the LMC Catalog. The cable shown as Type (2) is the one I have in mine.
Fred
Posted: March 31, 2010, 8:50 pm
by MadMaxetc
The stock cable works, but you will probably have to change the gear to get the speedo to work right (fast/slow).
Posted: April 1, 2010, 8:59 pm
by unibodyboy
Tacoma speedometer ... they will take care of you.
