Hi All,
I could use a little help.
I'm pretty new to the site. I picked up my truck around new years.
I'm doing the rear brakes on my '66 F-100 2WD Styleside Short Bed.
The axle grease seals are blown out, so I need to replace them.
It has a Dana 44 rear end. Part numbers for Bearings and seals are all over the map. A lot of the listings say except Dana Spicer! I've got the 9" ford rear ends covered but this is my first Dana.
I got the bearing numbers off the old ones, turned out to be a Timken SET7. That matches up to a '73 F-100 or so.
Today I found some backing plate gaskets with 5 holes instead of 4 on mine. They look like they'll work fine.
The grease seals are still a mystery. I'm going to try an SKF 18545 tomorrow.
Anyone have any experience?
Thanks,
Steve
Dana 44 Rear Axle seal help, 66 F-100 2WD
Riverside Racer
66 F-100, Short Bed Styleside, 352 V8 Auto Trans
Riverside Racer
