wiper motor wiring??????help please
ok so here it is........how do you tell which wire on the motor goes where....there is three wires coming off of it.. a green red and black...and there is a spot to hook up the ground wich i found but that still leaves me three to figure out and im not that good with wiring.... and the thing that is confuseing me is that i am hooking it up to a painless windshield wiper switch....any info would be great thanks alot...ill try to post some pic in a min. or.two. thanks
- slickmainer
If you can get me the wiring diagram for your Painless switch, I might be able to get you the proper wire placement. I just went thru this last summer when I did mine. I hooked mine up into a switch on the column by the way of relays so I have the wires marked with what they do coming out of the motor.
Kevin
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
63 F100
