what year and model did the 262 inline six come In
ebentraywick
Post by ebentraywick »
owning a slick.,,, priceless :)
1961 ford f350
1959 ford f100. not a slick but still goood looking
]Image
in pickups 1964
they were in earlier big trucks
ebentraywick
Y only 1964?? I have one in my 59 f100 its a sweet motor a strong thing 2
1961 ford f350
]Image
post a pic of it .... i thought i had a 262.... NOT....its a 223
ebentraywick
okay will do
1961 ford f350
]Image
ebentraywick
1961 ford f350
]Image
ebentraywick
p
Im going to take her out and give her a clean up ford blue or chevy oarnge paint??
1961 ford f350
]Image
BarnieTrk
Post by BarnieTrk »
ebentraywick wrote:Y only 1964?? I have one in my 59 f100 its a sweet motor a strong thing 2
ebentraywick,
Someone besides FoMoCo put it in your '59.... :shock:
My information tells me that the 262" inline 6-cylinder engine was only produced from 1961-1964. It was a truck use-only motor, where most were used in the bigger 1961-64 C550/C600 tilt cab trucks, F500/600 trucks and B600 busses. The only year is was used in an F100/250(4x2, 4x4), F350 trucks was 1964. Many engine parts interchange with the 223 with minimal to no modifications necessary. Also realize that there were two types of 262s...a 262-Light Duty (mainly used in the smaller trucks) and a 262 Heavy Duty (used in the larger trucks).
An easy & foolproof way to determine if you've got a 223 or a 262 is to pull a sparkplug and poke a 10" piece of stiff copper wire down the cylinder bore. With the piston at the bottom of its stroke, mark the copper wire at the sparkplug hole. Turn the engine over (by hand) to bring the piston up to the top and mark the wire again. The stroke of a 262 is 4.03"; whereas, the stroke of a 223 is only 3.60".
BarnieTrk 8)
ebentraywick
thanks dude i know that it is a 262. what is fomoco?? but just for the heck of it ill try your idea out
1961 ford f350
]Image
i wish i was half as smart as some of the guys on here.... BUT
im pretty sure thats a 223
oil fill should be in the middle of valve cover, not the front
... i guess it could have a 223 head on it though
ebentraywick
yes there is a 223 valve cover on it the 262 was a little rusty
1961 ford f350
]Image
fire truck
Post by fire truck »
ebentraywick wrote: what is fomoco??
Please tell me that is some kind of joke! Really!
ebentraywick
yes it is, my buddy asked that me the other day and i just chouldnt help my self 2 be a dork.
1961 ford f350
]Image
BarnieTrk
Post by BarnieTrk »
FoMoCo = Ford Motor Company
Cool...... I hope you come back here and report your results!:thumright:
BarnieTrk :cheers:
ebentraywick
well I did It came out to 4.03
1961 ford f350
]Image
64shortbed
Post by 64shortbed »
Is the distributer interchangeable with the 223? I seem to remember my grandpa fretting over not being able to find a replacement years ago. I don't know why, it seems to be in good working order.... Also, my valve cover is argent or a silver-type color.
-don
'64 F100 262-I6
64shortbed
My manual says that 262's have timing gears, wheras the 223 uses a timing chain
-don
'64 F100 262-I6
BarnieTrk
Post by BarnieTrk »
Don,
I'm pretty certain there are differences between early and late 223 distributors due to a difference in their oil pump drive attachment.
I also think there are more than one type of 262 distributor, possibly due to the differences in application of the Light Duty 262 and the Heavy Duty 262 (used in the 500/550/600 bigger trucks).
I don't believe any of the 223 distributors will interchange with any of the 262 distributors.
Just my :2cents:
BarnieTrk
mikewirth
Post by mikewirth »
Is that the original grille? I had a 1959 and it was not cubed pattern for lack of better terms, it had 5 or so horizontal bars running across and if I remember right the 1960 had 1 big bar between the lights
BarnieTrk
Post by BarnieTrk »
mikewirth wrote:Is that the original grille? I had a 1959 and it was not cubed pattern for lack of better terms, it had 5 or so horizontal bars running across and if I remember right the 1960 had 1 big bar between the lights
At that angle, it looks more like a '58 grille to me...... ?? :dontknow:
Here is a pretty good Ford grille chart from jakdad: http://www.1966ford.com/images/BIG48-72.JPG
BarnieTrk :popcorn:
