They are available from Summit and others for FE engines, and are a medium length.
First I tried the driver's side. The steering cleared OK, but the header's hit on the engine perch. I have a 66 F-250 with manual steering, and on close inspection, it was obvious that the power steering perch was needed.
So, off to the auto wrecker's and I got a perch from a power steering truck.
I changed to this perch ( there are holes in the frame for it ) and the headers went on.
Now the easy side, the passenger side. The headers slide right up from the bottom. But, how to get the starter on?
So, I pulled the header back out , and installed the starter.. Then the headers won't go in, the starter is in the way.
[/img]
