the day after
Here is the forum for the next great Event
the day after
back to the grind, staving off the withdrawal symptoms
first off had to check out the van , r front brake was sticking on the way back from airport last tuesday.
took off the tire, nothing looks out of place
loosened the bleeder screw, caliper moved back freely, not stuck. wheel bearing a bit loose, nothing major. adjusted both front wheel bearings.
drive up to the gas station, hardware, and auto parts store, van drives fine , no issues.
wife calls me, we meet at the p.o. house of the dumptruck and load up the old trans with the pto i need.
had dinner, crawled under the dumptruck to drain trans oil and remove pto cover
friend calls he has flat tire on backhoe on the highway.
fill up air tank, go put air in tire, follow him back to my house.
we plug the tire, he removes several big tree stumps for me, then i follow him home.
got back and picked up all my tools.
no one to sit in the yard with till 3am and bs with so i went to bed.
quietwyatt
Post by quietwyatt »
Why not ask the wife to go out to the yard and sit until 3:00.
:rotflmao:
Was good to meet you Brian. Shifter knobs already on. :D
Wyatt
1965 F-250 (Betty Boop)
ezernut9mm
Sweden
Post by ezernut9mm »
brian, i tried leaning on the bedside of my truck with a beer for a while yesterday evening and it wasn't the same alone. lol. oh well, only two more years and i can do it again.
foodstick
Post by foodstick »
You know that is a problem..it was sure fun staying out late..But that darn KID had stuff scheduled all the next day ! ;)
ezernut9mm wrote:brian, i tried leaning on the bedside of my truck with a beer for a while yesterday evening and it wasn't the same alone. lol. oh well, only two more years and i can do it again.
I hear you there buddy.
Casey 65
Post by Casey 65 »
come on over, we can lean on mine and drink beer...
Casey 65
Post by Casey 65 »
62galxe
Post by 62galxe »
Judgin from the bottles in the bed the next day I figured my truck was a good leanin post. :lol: glad yall put it to good use.
1963 uni PATINA BLUE
1965 short bed
