difference between np435 2wd and np435 4wd trans
19slick66
Post by 19slick66 »
Well after reading about the price for the cane replacement, I searched for a cheap trans. I picked up a np435 for 4wd. Top was in perfect condition and was a direct swap. I know the 2 cases are different, and my tail stock will not fit the 4wd case. Obviously the output shaft is different as well. So, My 66's gears are a little chewed up, Not bad but noticable. The replacement parts are in like new condition.
Do you know if the internals of the np435's, meaning the gears, syncro's, etc are all the same or not?
I would like to swap out all the internals if they are.
robert porterfield
Post by robert porterfield »
in a word yes, you can "re-case" the 4x4 with your 4x2 case....use all internal parts, no mix and match, if going to try verify your tooth counts, 435 has several aval 3rd gear ratio's so watch out for that, but from what i gather form your post shold be direct case swap.... 8)
lifes hard wear helmet!
19slick66
Post by 19slick66 »
thanks. I really do not want to let this new gear set go.
