No slick ford truck question 94 F150
My Dad has a 94 F150 and he wants to check the circuit from the tank selector switch. Front tank won't pump fuel. Can't find the information in his manual any body know what to do? Thanks Guys!
shawns fords
Post by shawns fords »
Greg its been a while since ive picked up a service manual but I can remember having relays in engine compartment as well as the switch itself, follow power from switch out. you can pop it out really easily. by taking the black cover off from around instrument cluster to gain access to the back of switch. check power to it, should have hot wire going in and going out on the one tank selection if you switch to other side power should go to another terminal to go to other tank.
Moose
Post by Moose »
Sounds like the fuel pump selector circuit has gone south. The fuel pump selector valve is on top of the front tank. Ford had a problem with these a while back, but now won't acknowledge it.
Also, is the rear tank pumping? If not look on the passenger's side foot well, under the trim panel. You will find a switch with a button on top. Make sure that the swicth is down. If it is up, then push it back down....
Moose
American born, German blood, Texan attitude..... And people wonder why they call me "Moose."
66 F-100 Too much to list
05 F250 The Tank
He has been driving it of of the rear tank for a long time, thanks I'll check the above. I personally think the in tank pump pooped.
FORDBOYpete
Post by FORDBOYpete »
I believe the 86-96 have one pump and a circuit that controls a valve that switches between tanks.
Also in that circuit is the fuel level readout guage. :thumright:
If the front tank doesn't register any fuel in it, besides failing to pump when it does have fuel, then
you need to be doing what Moose said and start checking why the swicthing circuit isn't working right. :hm:
This is assuming the pump does not run when switched to the front tank position. If the pump does run
& you get fuel level readout, but no fuel, then your problem's with pick-up or draw tube in the front tank. :roll:
Change is the Only Constant
adrianspeeder
Post by adrianspeeder »
FORDBOYpete wrote:I believe the 86-96 have one pump
'89+ was the switch to the single high pressure pump mounted in each tank. I don't have the link here on my laptop for the complete fuel system troubleshooting guide, but I'll get that posted tonight.
Also many topics of discussion on the fuel system in the pre '97 section here...
http://www.f150online.com/forums/forumdisplay.php?f=51
Adrianspeeder
