Rebuilding my 4x4
Jerry T
Rebuilding my 4x4
Post by Jerry T »
It is time to repaint the old girl. In the last couple of years I have Built the motor and went through the rest of the running gear. it is a 66 on a 78 F-150 4x4 running gear. I have pulled the bed off and have been straightening out the fender wells and floor. I have got a few places on the outside of the bed to touch up, then I will prime the bed and start tearing down the rest of the truck. It doesn't need to much body work, realy just a good sanding and paint. I am going to go back Springtime yellow and Wimbelton white.
The cab corners are still in good shape
slickmainer
Post by slickmainer »
nice, i dig those 4x4's. looks like you have several in the yard to pick from
--Gregg--
you can't get there from here
Casey 65
Post by Casey 65 »
Looking good! The color combination sounds nice too.
HiBoy63
Ireland
Post by HiBoy63 »
Lookin good that should be a nice color combo.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
Heritage country Flag
Jerry T
Post by Jerry T »
I do have a few parts lying around :lol:
Anthony
Post by Anthony »
SWEEEEET!!!!! Love those 4X4's!!! and the bright colors.... all I ask ia a lot of picture updates... :wink:
Reds Rod Shop
Post by Reds Rod Shop »
Anthony wrote:SWEEEEET!!!!! Love those 4X4's!!! and the bright colors.... all I ask ia a lot of picture updates... :wink:
I'm with Anthony :laughing: Lots of Pictures. I am hoping to start on a 66 4x4 pretty soon.
Jerry T
Post by Jerry T »
Havn't posted anything in a while. i have the bed pretty much ready to paint except for cleaning and priming underneath. Got the truck in the shop and striped it to a bare cab. Had to repair some places in the floorboards. Also I am grinding out all the old filler and replaceing it with a filler caled Metal to Metal. I like it, it is not suposed to shrink or crack, and it works fairly easy. I have the outside of the cab, and doors done and primed. Now I am working on the fenders, hope to prime them tom. I keep putting off finishing the inside of the cab, because there is so much hand sanding. Here's some pics, I will try to post sooner next time.
Image[/img]
Anthony
Post by Anthony »
that is coming along nicely!!! just out of curiosity?.... what kind of a gap is between your bed and cab with it sitting on a new chassis?? mine is almost 3 inches on my 66 on a 76 chassis... just wondering how someone else who has the newer chassis is....
Jerry T
Post by Jerry T »
Anthony, the gap on mine is about "1". It is more than stock, but not enough to realy notice.
Gas4blood, it is a 31 coupe. I choped it "2 1/2" and moved the firewall back. i am going to set it on a 32 frame and run a 3 deuce 427 ford and a 4 spd in it. Should be a fun toy.
Jerry T
Post by Jerry T »
It will be a while on the coupe. The most important thing is it's paid for, and in the dry.
Jerry T
Post by Jerry T »
Still slowly making progress. I have everything except for the inner fenders and tailgate primed now.
I also welded up the holes in my clutch linkage that had worn over the years. Then i welded the brakelight switch bracket from a 78 to my pedal, and made a striker for the switch to hit. I was tired of the pressure switch.
I found a set of mirrors today at a junkyard for $10.00 :woohoo:
I have been running a factory set off a 67-72 on left
These are factory towing mirrors I think, off a 67-72. They stick out a little farther. even got a ninga turtle horn in the deal.
Got it picked up with the wrecker now washing the frame and bottom of the cab.
Mabey I can get some paint on it soon
Paul Merrell
Post by Paul Merrell »
Better hold onto those mirrors there getting harder to find. The ones on the left I what I use on my truck and I just replace the zinc nuts and bolts with stainless only cost me $16.00 and they look great.
slickmainer
amazing what you can do when you have space and a nice "lift" haha, looking good. I love the 4x4's
--Gregg--
Jerry T
Post by Jerry T »
Got the frame painted this morning. It feels good to be doing something to make it look better instead of tearing it apart.
This afternoon I painted the dash white, also painted the white trim in the door jambs. As hot as it is here the paint may be cured enough to tape it up and finish the inside of the cab tomorrow.
I just had to see how the yellow was going to look, so i painted the inside of the fenders. It is going to look good.
It looks white in the pics, but I promise it is springtime yellow.
Jerry T
Post by Jerry T »
Got the yellow on the inside of the cab and doors.
It is going to look different than it did!
Paul Merrell
Congratulations Jerry that looks good then comes the fun part of putting it back together.
fire truck
Post by fire truck »
lookin good bro!
Jerry T
Post by Jerry T »
Thanks, Now when my door rubers come in I can get the doors back on and start block sanding. fun fun fun
slickmainer
it's gonna be sweet. i like that springtime yellow
--Gregg--
