air ride??
Anthony's Son
air ride??
Post by Anthony's Son »
so i'm trying to figure out how to do the air ride the cheapest way possible...
so if you all have any suggestions let me hear it... and will i have to four link
the back?
Zak
1963 uni short bed
sub framed tubbed
351W carbed and C6 are the plans now..
1963 Short bed Flareside
302 3 speed
Daily Driver
thenephilm
Post by thenephilm »
Air ride and cheap aren't necessarily compatible lol. You have a better start with the chevy front clip as it will be easier to bag. You will have to buy or make bag cups up front and possibly get drop spindles depending on wheel/tire size. In the rear, I would definitely run a four link suspension, which you can make yourself with some DOM and some bushings from qualityairride.com. The four link style you go with will depend on what you want to do with the truck. I would run a forward triangulated four link for most applications, however if you were looking to put down some power or tow, I would run a parallel four link with watts link in the rear. Examples of both can be seen on that same link that I listed. You may to notch the frame and the bed floor for axle clearances but you can make a notch out of some 2x3x1/4" tubing.
As far as bag placement in the rear, placing the bags on the four link bars will provide for a softer ride but I would recommend running the bags over the axle for towing purposes. I would run slam specialties re7s all around with 3/8 valves. I would run an engine driven compressor if possible as they do not drain your electrical system and are quite a bit faster. You can convert an old AC pump to work as one. You would need an air tank as well, at least 5 gallons worth. I would say you would probably have well over a 1000 in the air ride, but my suggestion would be to constantly check craigslist in your air for people selling air ride parts used to help offset the cost. Also, look at the book Chassis Engineering by Herb Adams for details on setting up the four link suspension correctly.
You can always PM me or dragginwagon or twistedfreak as I know we all have experience with air ride in other applications and have messed around with it for years. I hope this helps.
