Flat towing
Paul Merrell
Flat towing
Post by Paul Merrell »
For you guys that have a 4 speed NP 435 make sure you pull the driveshaft. Because if you don't pull the driveshaft you will burn up third gear and third, fourth sycronizer. Don't ask me how I know!!!!
62galxe
Post by 62galxe »
also the 2 speed fordamatic doesnt like it either.
1963 uni PATINA BLUE
1965 short bed
Paul Merrell
Well I now have a good 4 speed but had to buy a 65 F250. The good engine, trans, axle, drivers door, hood and a 67-72 bed. The bad cab, passenger door, front fenders, core support, tail gate.
jmf66
Post by jmf66 »
Thanks for the warning. How far did you tow?
jerry
unibody madness
Post by unibody madness »
I lost my C6 after towing it at speed for about 10 miles, with someone,not a tow truck driver, doing me a favo.r not only distance but speed...Tow truck drivers should know but I believe its anything over 45 can do damage. Best to disconect the auto trannies or tow from the rear.
John
Paul Merrell
I towed mine 20 miles one way turned truck around and towed it 20 miles back home. Messed up the sycro and needle bearing between input shaft and output shaft. I bought a junk truck pulled transmission and took the good parts out of it and put in mine. For all the 4x4 owners a NP435 is differtant than a NP435 in a two wheel drive. Also if anyone needs a case for a two wheel drive I have one along with a input shaft and output shaft
