lowering the sides of a long bed
milldogg22
Post by milldogg22 »
i was wondering if anyone out there has done or has seen a long bed stepside that someone lowered the bed sides to match the height of a short bed. i would like to lower my bed sides down so they would match the cab lines better. i guess maybe cutting out the lower section of the bed sides. i think if the sides where 2.5 inches lower it would look alot better.. just seeing if anyone has any input on this... thanks
slickmainer
Post by slickmainer »
i can't quiet picture this, i'll have to google some images. seems like a bunch of cutting though.
--Gregg--
you can't get there from here
foodstick
Post by foodstick »
I think possibly Matt scratch built his own box side pieces.. I always thought the bed sides looked about 4-5 inchs to tall as well.
It could be done different ways i suppose.. it depends on what you want it to end up looking like .....
F7BIGJOB
Post by F7BIGJOB »
I like 'em high :2cents:
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
slickmainer
Steve I love your truck. anytime you want to trade you just let me know! :lol:
--Gregg--
65fordguy
Post by 65fordguy »
you could do it like a lot of these guys who slam their trucks... cut all the cross members and get the bed where you want it.. ( you may have to notch the front of your bed) ..and attach the bed either with new cross members or mounts of your choice.. this way your exterior bed sheet metal is un harmed. You will also need to attach a new lip for your floor to rest on.. angle iron/ 1x.. whatever.. I was going to use angle and drill holes and plug weld .. now you have a new mounting surface.. you could actually attach your new cross members to this... This is the method I considered doing when I still had a step side ( short bed ) I wanted to lower ( not much -- just a little ) the bed and give the appearance a lot like the older fords with a larger cab and smaller bed.. too me the step beds on these trucks over power the cabs.. doing this on my truck would of required raising the steps and shaving the bottom of the fender.. you may be able to get away with it on the larger beds though.
Post by Gritsngumbo »
Me too!
foodstick
Post by foodstick »
At the risk of starting a double wrong box thread :)
is the stepside they used an EXACT version of another earlier trucks box, or is it unique to our trucks? it seems strange that it also doesn't come down low enough to match the cab at the bottom also...
DirtyHerri
Post by DirtyHerri »
No, the Slick step-side (flare side to use correct Ford term) are somewhat different than the earlier Ford trucks.
I believe the area that meets the steps are different. Also, I've been told the holes for the fender or either higher or lower (can't remember which), but I have never confirmed this. I would measure the slick bed against my '56, but I on long have the slick flare-side bed (sorry..).
So, even though the Slick and the earlier beds look very much the same it appears Ford did change them some.
Also, I agree about the flare-side bed looking a bit tall in respect to the cab on slicks. I though seriously about doing a small chop/channel or whatever hot rods call it to the bed-side on my truck. However, I found a great deal on a style-side bed and ended up just switching to that bed.
Dirty Herri
1962 Ford F100
1956 Ford F100
1969 Mustang Fastback
ezernut9mm
Sweden
Post by ezernut9mm »
how is jim's truck done? the lowered green 66 long flair side. his name's jim isn't it?
jeepbut
Post by jeepbut »
Chris, I think the green truck you are thinking of used 78-79 step side bed sides. They came from the factory flat on top. Could be 77 also, but I think only 78-79. Thanks, Lyman.
36truck
Post by 36truck »
Yes 77 had the flat tops also.
Tom Williams
fire truck
Post by fire truck »
Didn't the flat tops start in 73...
tomsrod
Post by tomsrod »
Nice truck! Great colors too. I've always liked the flareside long beds with the high sides.
HiBoy63
Ireland
Post by HiBoy63 »
I cast my vote for leaving em High. :thumright:
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
Heritage country Flag
Is there a step that goes between the cab and the front of the rear guard?, if not, they would be a bugger to work out of! :(
F7BIGJOB
Post by F7BIGJOB »
Alan Mclennan wrote:Is there a step that goes between the cab and the front of the rear guard?, if not, they would be a bugger to work out of! :(
Alan yes steps are supposed to be there, just the one set I have,have New England patina= rotted to death.
F7BIGJOB
-Steve
MadMaxetc
Post by MadMaxetc »
A little Photoshop Fun...
[albumimg]9358[/albumimg]
My Build Thread
F7BIGJOB
Post by F7BIGJOB »
My donor bed [junk- sittin behind garage] po painted the top inside and the top outside white to match the red/white cab it was on. Didn't look too bad [coming from me , a portagee], but not enough to paint my new bed like that.
Dan [to me] that is amazing what you can edit on a pic :shock:
F7BIGJOB
-Steve
Rusty 63
Post by Rusty 63 »
The Carpenter (Dennis? Dan? - I always get them confused) that makes beds can make them the way you want...
