DOOR SWAPS FOR 65 F100
JOELHEWITT
Post by JOELHEWITT »
I've got different info from others, so I knew y'all would know FOR SURE!
What year range will fit 1965 F100?
When I mean fit, I mean not only bolts up but also body lines visually is the same.
Located JUST SOUTH OF ATLANTA GEORGIA C.S.A.
Uncle Skip
Re: DOOR SWAPS FOR 65 F100
Post by Uncle Skip »
Unless it is a Unibody, all doors from 1961-1966 are interchangeable.
any 61-66 non uni , f/n with angle on bottom.
but they all fit and bolt up
there is a cosmetic difference on the inside of the 65/66 doors in that the indented lines are different this does not afect fitment
uni door
conventional cab door with dip in body line
door with angle on bottom cant use for obvious reason
1612
inside early door
inside late door notice indents different
