show me your guages
shocker998md
show me your guages
Ive been looking, and im un sure of what I want to do with my cluster. I have a sweep cluster in my 66, its looking pretty beat.
Im not sure if I want to clean it up and paint it silver, maybe throw some more guages on the side as in oil pressure and volts. Then maybe even replace the temp and fuel guage since they have been acting up and I think they are both bad. Yes ive changed the voltage thingy behind the cluster.
Im also not sure if im digging the shiney repops that are in D.C. So can some people put up some pictures of there cleaned up sweeping clusters? thanks guys.
Re: show me your guages
I replaced my sweeping cluster with a round full gauge set out of an early Bronco and got a Bezil out of the bone yard. cleaned and painted, stripped the aluminum around the cluster and ordered white face overlays for mine.....
this is how I "fixed" my sweep cluster.... I like the round set ...
- charliemccraney
Speedo, tach, oil pressure, coolant temp, fuel level, volt, vacuum/boost, fuel pressure, a/f ratio.
Here's a link to a template you can use to play around with the layout.
viewtopic.php?f=5&t=15238&p=131907#p131907
Last edited by charliemccraney on January 6, 2012, 11:35 am, edited 2 times in total.
- slickmainer
I kept the sweep bezel but just sprayed it black. the bezel was good, the plastic glass behind it is whats crappy. I wish they sold the new bezel pieces separately.
--Gregg--
you can't get there from here
- Blackwaterforge
I used a chrome cluster out of a F-800 with vacuum and tach.
shocker998md
maybe i worded it the wrong way. im looking for pictures of the other cluster, not the big round one. I saw your mainer, thats one of the few ive been able to dig up on the search.
- Alan Mclennan
sorry this is the best I have a the moment
- Hoofbeat Racer
turtle1056
Alan - that is the best rendition of an aftermarket dash I have seen to date.
What did you use for the billet part? What was the original application?
what was the panel that holds the guage assembly made of? and what is the finish on it?
This would look awesome in my 64 when it comes time
thanks
Ken
thanks
Ken
64 F100 shorty, slammed hotrod 302 truck efi
65 M 100, gasser, blown sbc
94 monster Dodge diesel4x4
91 F350 700 hp cummins diesel
96 Sebring convertible
- Uncle Skip
deadheadno1
This is the only one I have on the 'puter right now. The left side will have an air pressure gauge. I've got three of these chrome panels cleaned and ready for use now.
Sorry about the size of the pics, I haven't got that part figured out yet.Tom
- slickmainer
- Alan Mclennan
turtle1056 wrote:Alan - that is the best rendition of an aftermarket dash I have seen to date.
thanks
Ken
Thanks Ken!, I felt sure it was a Billet Specialties dash panel, but I don`t seem to be able to find a link showing it!, I`ll keep looking tho,
the panel behind it is a standard panel with a metal blank covering the old holes, and is painted with what I called Cranebrook Chrome!
Here's my gauge panel. I cut out the side hole indentions and had the panel powder coated in a chrome finish. Then I installed a couple of Classic Instruments gauges in the holes. I'm pleased, through it turned out pretty nice.
- qwertyd10n
Here is mine...
The two side gauges (voltmeter and oil pressure) are 2 1/16" offerings from Autometer's Traditional Chrome series... the the mini tach is a 2 5/8" unit from the same series.
Cheers,
Dion
Cheers,
Dion
Here's my Dakota Digital VHX set. They will probably end up in my Uni.
One of our local members made a plexiglass panel that i really like! It would be a good match for the double-DIN blacked-out touch panel in my low-riding 65.
Alan,
how come you didn't get a metric tachometer to match the speedo?
Toyz wrote:Alan,
how come you didn't get a metric tachometer to match the speedo?![]()
