header question?
lane
header question?
Post by lane »
So I'm dropping a real pretty 390 FE as well as a newly rebuilt C6 transmission (with a shiny Lokar floor shifter) into my 63 Unibody (used to have a 223 6 in it with a three-speed on the column. I've ordered crossmembers for both engine and the transmission from Dennis Carpenter and everything seems to be great - except now my Hedman Headers won't work. They hit the new cross-member perfectly wrong. So, I'm looking to find some headers that will work on my 63. I'm guessing I can get away with using some shorty headers, but before I order some, I thought check and see what smarter guys than myself are doing on theirs. Any and all input is very appreciated.
Lane
A happy life is a simple life.
cooter
Re: header question?
Post by cooter »
which crossmember does it hit? Can you notch it?
lo6fo
Post by lo6fo »
ill second what cooter said. try and see if you can notch the crossmember. it may save you a bit of money since you wouldnt need tou buy a second set of headers
64 f100 long bed 292 with a 4 speed
lane
Post by lane »
Thanks for your response. It's a pretty direct hit on the new crossmember. Keep in mind this new crossmember isn't stock and it's not the big existing crossmember on the frame. It's an after-market crossmember sold by Dennis Carpenter for guys like me who want to put a big FE block into a 63 unibody. It's only intended to hold the engine (can't cut it without losing a ton of stability for the motor - it's round tubing, about 2 inches inches diameter with motor mounts welded to it). The header tubes aren't much smaller in diameter than this new motor mount/crossmember's tubing. I don't mind getting new headers. My engine is show-quality and these headers are not new. I more would like to know what other people are using for headers or if someone has a different idea for running them. Plus, I think I'd have a hard time (mentally) cutting a notch out of my crossmember - I'm sure there is plenty of strength there, I'm just a little weird that way. :)
Lane
cooter
Post by cooter »
if you have a tubeing crossmember then notching is not an option. look at fordpowertrain.com for some header options or stans headers. i would think any car header would be the right fit
