66 2wd to 4wd question?
brent460
Post by brent460 »
Ive got a line on a cheap 78 bronco for most of the parts needes. But how much would I have to lift it to clear the 2wd crossmember? Or just whats the best way to do the swap?
"Ambition is a dream with a V8 engine."
Elvis Presley
Re: 66 2wd to 4wd question?
brent460 wrote:Ive got a line on a cheap 78 bronco for most of the parts needes. But how much would I have to lift it to clear the 2wd crossmember? Or just whats the best way to do the swap?
your wanting to put the 66 cab on the bronco frame? it will bolt right on.
if you want to take the bronco axles and transfer case and install them on your 2wd frame forget it, too much fabrication.
best if you want 4x4 to find a 67-72 f100/f250 (easiest) 4x4
or a 73-79 (a slight bit more work, not much) and put your cab and bed on it.
Anthony
Post by Anthony »
:iagree: mine is on a '76 chassis... check out my build...
